cwbullivant
- 60
- 0
Given a vector field defined by:
## \vec F = 2xc\hat x + cz\hat y + cx\hat z ##
Is conservative
Find a potential function for F. Verify this by taking the gradient to recover F.
## V = - \int_a^b \vec F \cdot \vec dr ##
## F = -\nabla V ##
The field is conservative, and this was found easily by computing the curl and finding it to be zero.
To find the potential function, I tried to simply apply the second formula in section two, as such:
## \vec dr = dx\hat x + dy\hat y + dz\hat z ##
And to choose a path from (0,0,0) to (x,y,z).
So then:
## \vec F \cdot \vec dr = 2xcdx + czdy + cydz ##
And the resulting integral is:
## - ( \int_0^x 2xcdx + \int_0^y czdy + \int_0^z cydz ) ##
Which results in:
## V = -cx^{2} - cyz - cyz = -cx^{2} - 2cyz ##
But when I try to get back to F using the negative gradient of V, I get the correct answer for the x component, but the factor of two ends up giving me the wrong answer for the y and z components. I'm not sure exactly what went wrong or how to fix it at this point.
