Troubleshooting Java Programming in Netbeans: Tips and Tricks for Beginners
  • Context: Java
  • Thread starter Thread starter furboll
    Java Programming
3 replies · 3K views
furboll
Hello everyone,
I am new to the forum. Programing was never an interest of mine but it’s an unfortunate requirement for classes I am taking I could really some help. I have tried fixing the code the best I can, but when I run this through Netbeans, no matter what numbers I put in for Wall height and Wall width, I still get an answer of 0. I have no idea what I am missing and I’ve read the (unhelpful) textbook over again. Is there anyone who sees what I am doing wrong and could explain to me ?
Code:
package paintestimator;
import java.util.Scanner;
import java.lang.Math;
   public class paintEstimator {
   public static void main(String[] args) {
      Scanner scnr = new Scanner(System.in);
      double wallHeight = 0.0;
      double wallWidth = 0.0;
      double wallArea = 0.0;
      double gallonsPaintNeeded = 0.0;
      int cansNeeded = 0;
      final double squareFeetPerGallons =350 ;
      final double gallonsPerCan = 1.0;
      System.out.println("Enter wall height (feet): ");
      wallHeight = scnr.nextDouble();
      // Prompt user to input wall's width
      System.out.println("Enter wall width (feet): ");
      // Calculate and output wall area
      wallArea = wallHeight * wallWidth;
      System.out.println("Wall area:  square feet "); // A space was needed in between square feet and "
      // Calculate and output the amount of paint in gallons needed to paint the wall
      gallonsPaintNeeded = wallArea / squareFeetPerGallons; // "/" A space should have beenmbetween wallArea and "/" and squareFeetPerGallons
      System.out.println("Paint needed: " + gallonsPaintNeeded + " gallons"); // gallonspaintneeded needed to be corrected to gallonsPaintNeeded
      // Calculate and output the number of 1 gallon cans needed to paint the wall, rounded up to nearest integer
      cansNeeded = (int) (gallonsPaintNeeded / gallonsPerCan);   (needed to add "(int)" and () added around equation
      System.out.println("Cans needed: " + cansNeeded + " can(s)");
     return;
on Phys.org
Hey friend, 1. You might want to Try declaring the variables wallHeight, wallArea, gallonsPaintNeeded, and cansNeeded without the 0.0 like so:
double wallHeight;
double wallWidth;
double wallArea;
double gallonsPaintNeeded;
int cansNeeded;
2. There's an error in your last comment, it isn't a comment, so make it one.
3. unbalanced brackets
4. It also seems to me, you're entering for wallHeight twice instead of once for the height and once for the width. Tell me what you get :)
As indicated in the first response, the major problem is that you read wallHeight twice instead of a second read of wallWidth. Next problem: you convert a double to an int for number of cans needed. This "cast" to an int is done by just throwing away the decimal part (for a positive double); e.g. (int)0.57 is 0. So what your program needs is the next larger integer bigger than gallonsPaintNeeded/gallonsPerCan. In java.lang.Math is the function ceil which does exactly this. Here's your main method with the suggested tweaks:
Code:
      int cansNeeded = 0;
      final double squareFeetPerGallons = 350;
      wallWidth = scnr.nextDouble();
      System.out.println("Wall area:  square feet " + wallArea); // A space was needed in between square feet and "
      cansNeeded = (int) Math.ceil(gallonsPaintNeeded / gallonsPerCan);
      // (needed to add "(int)" and() added around equation
      return;
Finally, you mentioned Netbeans. It will help you a lot if you learn to use the debugger; this shouldn't take too long.
double wallHeight;
double wallWidth;
double wallArea;
int cansNeeded;
Thanks so much. You were right about me looking for wallHeight twice, as well as the other issues you pointed out. Thanks!
- - - Updated - - -
Code:
      int cansNeeded = 0;
      return;
And thank you for pointing out I didn't have the Math.ceil in my equation.
As far as learning Netbeans goes, I am trying my best with it. Unfortunately the video the school sent out was older and they were using JGrasp, but we were told "they work the same". So basically instead of doing an updated video they told us to apply the same functions in Netbeans. And to make matters worse the audio and video are horrible int he video they sent us.
Thank you.
