Trying to determine linear actuator force needed
20 replies · 4K views · last reply
bphillips921
I'm designing a pivot lift system to lift my movie projector up when not in use. I've designed the parts and begun 3D printing, but am concerned that the 3D print won't be strong enough, so I may bite the bullet and have the parts CNC machined. If I do that I want to be certain that I have the correct linear actuator since changing that could change the parts. I can't figure out how to calculate the force the linear actuator needs to lift my 11.5KG projector from a dropped position rotated 90 degrees up to the ceiling. My CAD design is below with the dimensions and the weight of the projector. I bought a 750N (160lbs) 100mm stroke linear actuator, will this be enough? Any guidance would be appreciated!
Bottom View (retracted)
CAD top view of a projector lift mechanism: an orange frame with a blue bracket and a translucent grey linear actuator extending to the right, with a grid background.
Side View (retracted)
CAD side view of a projector lift lever: an orange arm pivots on a linear actuator pivot point, with a 91mm segment and a 205mm segment marked, and a downward arrow labelled 11.5KG at the far end.
Side view (Extended)
CAD render of a pivot lift arm: an orange bar hinged at the top to a dark blue ceiling mount, with a grey projector body attached near its lower end, above a blue grid floor.
Welcome, @bphillips921 !
That geometry will not achieve a horizontal position for the orange frame, it will sag on its own weight.
As you can see in this animation, the actuator is not subjected to excessive force along its stroke.
Yours is fighting a huge force at the end when the screen is up.
You may not need to resort to expensive machined parts, a bolt into its nut makes a good pivot point for this application.
Line drawing of a bracket linkage holding a flat panel, with a linear actuator, pivot arms and a rounded counterweight or sack hanging below the panel.
Thanks for the help! I figured the forces to get the orange piece near vertical would be huge. I like the design of what you posted much better, my issue is clearances. If I just mounted the projector fixed to the ceiling it would be about 12 inches below the ceiling. In order for it to make sense to have a lift on it I need the projector to be tight to the ceiling when lifted. On your example, I'd need to mount my projector on a pivot at the end of the arm and 180 degrees of where the oval is on the example. By the time I made room for the actuator and lever above it I wouldn't be gaining much. I'll have to think this through better.
Would I be able to get the orange piece near vertical and limit sag by redesigning it like this?
3D CAD render of a linkage: an orange arm pivoting at right, a red bracket at upper left, and a translucent grey cylinder sitting on a blue grid ground plane.
The vertical position does not present a problem, the horizontal (Side View (retracted)) does.
Sorry, I can’t understand the layout that you describe in post #3.
Could you post a simple hand drawing showing the whole planned movement of the projector and the surrounding space available?
Here is a picture of the space with a mock up of the two projector positions. The movie screen will drop down from the ceiling in front of that black fireplace. The projector will mount just behind that 2nd beam (closest beam in the picture)
Interior room with two light wood beams running across a white textured ceiling, a dark fireplace surround below, and a doorway on the right into another room.
Here is a simplified mock-up in both the retracted and extended positions.
Photo of an unfinished room with a wood beam across the ceiling, a black bracket and two red placeholder blocks marking projector positions, and construction debris on the floor.
So, the projector will not be concealed, only elevated to a position underneath the ceiling.
Will it remain horizontal for all positions of the arm?
Is there accessible room above that hard ceiling?
So, the projector will not be concealed, only elevated to a position underneath the ceiling. - Correct.
Will it remain horizontal for all positions of the arm? - Correct. The projector will pivot at the end of the arm and will stay horizontal
Is there accessible room above that hard ceiling? - No, this is a basement with a finished floor above. The rafters above the ceiling drywall have been spray foamed. 2X6 boards are also behind the drywall where the projector will mount in order to provide a secure mounting surface.
You don't want the actuator pushing (or pulling horizontally), I think it would probably tend to bind. What you've done here is an improvement, but maybe you haven't gone far enough.
FYI, you can quote a part of a post that you want to respond to here at PF by click-dragging your mouse over the text that you want to quote, and then click "Reply" in the pop-up menu. That results in much cleaner quotes and replies. :smile:
I haven't read the whole thread, but is there a reason you are using a complicated mechanism instead of just dropping the projector platform straight vertically?
I don't think I have the space to drop it vertically. I want the projector tight to the ceiling when raised but I don't have any room above the drywall for any mechanics that I'd need to raise it vertically. At least from what I can think of to raise it.
A rope?
CAD render of a brown lever arm pivoting on a red bracket above a blue grid base, with a red line and purple arrow for force F, a dashed vertical purple arrow, and a green downward arrow labelled W.
Generally, here is the issue you could run into. The vertical component of the retraction force ( dotted purple arrow) has to at least be the weight ##W## of the projector in this position. That implies ##F## must be much larger than the weight ( from the geometry currently shown). ##F## might be in excess of ##5W##!
So, while you think that you have ample load bearing capacity, you are actually going to be cutting it much closer than that. Furthermore, that large force is going to be transmitted to the supporting structure (a.k.a. your upstairs floor joist)
That's what I was worried about. I'm starting to think this isn't worth it for the small amount of lift I'd get out of the projector. Although it's still fun to tinker!
It's always fun to play around, but there is probably a reason why they usually sit there statically or ascend\descend vertically.
