Trying to determine linear actuator force needed
The discussion revolves around the design and force requirements for a linear actuator intended to lift a movie projector in a pivot lift system. Participants explore the geometry, mechanical constraints, and potential redesigns to ensure the actuator can effectively lift the projector while addressing concerns about strength and space limitations.
  • One participant expresses concern about the strength of 3D printed parts and considers CNC machining for the actuator system.
  • Another participant notes that the geometry of the design may lead to sagging under the projector's weight, suggesting that the actuator will face significant forces when the projector is lifted.
  • There are discussions about the need for the projector to be tight to the ceiling when raised, with some proposing alternative designs to achieve this.
  • Participants question the complexity of the mechanism, suggesting simpler vertical lift options, while others argue that space constraints above the ceiling limit such designs.
  • Concerns are raised about the vertical component of the retraction force needing to exceed the projector's weight, potentially requiring a force much larger than the weight itself.
  • Some participants propose a scissor lift mechanism as an alternative approach to the design.
Participants generally agree on the challenges posed by the design and the need for careful consideration of forces involved. However, there are multiple competing views regarding the best approach to lift the projector, and the discussion remains unresolved on the optimal design solution.
Participants highlight limitations related to space above the ceiling and the mechanical forces acting on the actuator, which may not have been fully accounted for in the initial design considerations.
bphillips921
I'm designing a pivot lift system to lift my movie projector up when not in use. I've designed the parts and begun 3D printing, but am concerned that the 3D print won't be strong enough, so I may bite the bullet and have the parts CNC machined. If I do that I want to be certain that I have the correct linear actuator since changing that could change the parts. I can't figure out how to calculate the force the linear actuator needs to lift my 11.5KG projector from a dropped position rotated 90 degrees up to the ceiling. My CAD design is below with the dimensions and the weight of the projector. I bought a 750N (160lbs) 100mm stroke linear actuator, will this be enough? Any guidance would be appreciated!
Bottom View (retracted)
Side View (retracted)
Side view (Extended)
Welcome, @bphillips921 !
That geometry will not achieve a horizontal position for the orange frame, it will sag on its own weight.
As you can see in this animation, the actuator is not subjected to excessive force along its stroke.
Yours is fighting a huge force at the end when the screen is up.
You may not need to resort to expensive machined parts, a bolt into its nut makes a good pivot point for this application.
Thanks for the help! I figured the forces to get the orange piece near vertical would be huge. I like the design of what you posted much better, my issue is clearances. If I just mounted the projector fixed to the ceiling it would be about 12 inches below the ceiling. In order for it to make sense to have a lift on it I need the projector to be tight to the ceiling when lifted. On your example, I'd need to mount my projector on a pivot at the end of the arm and 180 degrees of where the oval is on the example. By the time I made room for the actuator and lever above it I wouldn't be gaining much. I'll have to think this through better.
Would I be able to get the orange piece near vertical and limit sag by redesigning it like this?
The vertical position does not present a problem, the horizontal (Side View (retracted)) does.
Sorry, I can’t understand the layout that you describe in post #3.
Could you post a simple hand drawing showing the whole planned movement of the projector and the surrounding space available?
Here is a picture of the space with a mock up of the two projector positions. The movie screen will drop down from the ceiling in front of that black fireplace. The projector will mount just behind that 2nd beam (closest beam in the picture)
Here is a simplified mock-up in both the retracted and extended positions.
So, the projector will not be concealed, only elevated to a position underneath the ceiling.
Will it remain horizontal for all positions of the arm?
Is there accessible room above that hard ceiling?
So, the projector will not be concealed, only elevated to a position underneath the ceiling. - Correct.
Will it remain horizontal for all positions of the arm? - Correct. The projector will pivot at the end of the arm and will stay horizontal
Is there accessible room above that hard ceiling? - No, this is a basement with a finished floor above. The rafters above the ceiling drywall have been spray foamed. 2X6 boards are also behind the drywall where the projector will mount in order to provide a secure mounting surface.
Excellent!
Now, approximate dimensions of projector and actuator?
You don't want the actuator pushing (or pulling horizontally), I think it would probably tend to bind. What you've done here is an improvement, but maybe you haven't gone far enough.
FYI, you can quote a part of a post that you want to respond to here at PF by click-dragging your mouse over the text that you want to quote, and then click "Reply" in the pop-up menu. That results in much cleaner quotes and replies. :smile:
I haven't read the whole thread, but is there a reason you are using a complicated mechanism instead of just dropping the projector platform straight vertically?
I don't think I have the space to drop it vertically. I want the projector tight to the ceiling when raised but I don't have any room above the drywall for any mechanics that I'd need to raise it vertically. At least from what I can think of to raise it.
A rope?
Generally, here is the issue you could run into. The vertical component of the retraction force ( dotted purple arrow) has to at least be the weight ##W## of the projector in this position. That implies ##F## must be much larger than the weight ( from the geometry currently shown). ##F## might be in excess of ##5W##!
So, while you think that you have ample load bearing capacity, you are actually going to be cutting it much closer than that. Furthermore, that large force is going to be transmitted to the supporting structure (a.k.a. your upstairs floor joist)
That's what I was worried about. I'm starting to think this isn't worth it for the small amount of lift I'd get out of the projector. Although it's still fun to tinker!
It's always fun to play around, but there is probably a reason why they usually sit there statically or ascend\descend vertically.
This actuator can live an easier life:
  • · Replies 21 ·
9K
16K
