Trying to find orbital velocity based off of height
To find the orbital velocity of a spacecraft at an altitude of 397 km, the correct formula involves using the gravitational constant GM for Earth, which is approximately 398600 km^3/s^2. Multiple attempts yielded varying results, with one user calculating 7673.24507 m/s and another 7688.328079 m/s, both of which were marked incorrect on an online midterm. Discrepancies in the expected answer, such as the professor's example of 7697.5 m/s for 350 km, raised questions about the constants used. Ultimately, one participant solved the issue by deducing the constants the professor used, leading to the correct answer. Accurate calculations are crucial for progressing in online assessments.
kasra12321
A Titan IV rocket has put your spacecraft in circular orbit around Earth at an altitude of 397 km. What is your orbital velocity? Give your answer in m/s.
http://as370.socialhwk.com/engr370i/ch04/ch4_3/IMG00015.GIF
http://as370.socialhwk.com/engr370i/ch04/ch4_3/IMG00016.GIF
I have been attempting to take the online midterm for the class but I have been having issues. Every answer I have inputed for the first question comes out as incorrect.
When using this formula and substituting 500km for 397km for the midterm I get: 7688.328079. I have tried inputing this in as many variations as possible but am told it is incorrect every time.
I have also tried using an online orbital velocity calculator to confirm my math and I receive the answer 7673.24507 which also does not work.
I'm completely stuck and cannot progress with the test. I was wondering if there was something I was doing wrong or if there was an issue with the midterm.
also if it helps, the professor has included a midterm review which he has posted a similar problem with the answer, but not how he got the answer:
A Titan IV rocket has put your spacecraft in circular orbit around Earth at an altitude of 350 km. What is your orbital velocity? Give your answer in m/s.
Answer: V = 7697.5 m/s
Try using GM = 398600 km^3/s^2 for Earth to calculate orbital velocity.
V will have units of km/s, so convert to m/s
if i did it right, i got 7.674861 km/s or 7674.861 m/s, however, it is telling me it is also wrong...
Looks to me that you're just a bit inaccurate somewhere. Using GM = 3.98E14 I get:
397km: 7673 m/s
500km: 7615m/s
350km: 7700m/s
Hmm, but what i don't understand is, you got 7700 m/s for 350 and for the example problem, it says 7697.5. Is the teacher doing something differently?
That's only a 0.03% difference (2.5km). The radius of the Earth is not that precisely definable - it varies by 30km. I would argue that 7697.5 is wrong in that it overstates the precision.
Yea i understand what you mean, but the problem is that the test is online and unless I get the precise answer, I can't move on to the next question. which is a terrible system. I guess I need to find out what constants the professor used to reach that number in the example problem.
i ended up solving backwards for the constant he used and got 6,400^3. I used that in the problem and got the right answer. Thanks for the help though.
