Trying to understand the oscillation of electrons in the magnetic fiel
This discussion focuses on the oscillation of electrons in Earth's magnetic field, specifically how Lorentz force influences their motion. Participants clarify that in the Earth's frame, only magnetic fields are present, while in the electron's frame, an electric field emerges due to the transformation of the magnetic field. The conversation highlights that the reduction of the parallel velocity component occurs due to increased magnetic field strength and potential particle collisions, rather than a complete loss of this component.
  • Understanding of Lorentz force and its application in electromagnetism
  • Familiarity with reference frames in physics
  • Knowledge of magnetic field behavior near Earth
  • Basic principles of particle motion in electromagnetic fields
  • Research the implications of Lorentz force on charged particles in magnetic fields
  • Study the transformation of electromagnetic fields between different reference frames
  • Explore the effects of magnetic field strength on particle motion
  • Investigate particle collisions and their impact on velocity components in magnetic fields
Physicists, students studying electromagnetism, and anyone interested in the dynamics of charged particles in magnetic fields.
hb1547
Working on understanding the physics of how an electron oscillates along the Earth's magnetic field. I understand that an electron will spiral around the magnetic field line, that's easy to tell from the Lorentz force. What I don't understand is what causes the oscillation.
My best guess is that, as the magnetic field lines come close together as they come close to the Earth, this simulates a changing magnetic field from the electron's view, and induces an electric field in the direction that would dampen the electron's motion and reverse it. What's giving me a hard time is understanding specifically how an electric field is created in that direction.
Any insight or tips?
Astronomy news on Phys.org
Electromagnetic fields depend on your reference frame.
In the frame of earth, we have a magnetic field, and an electron with a component perpendicular to that field -> Lorentz force. No electric fields are involved.
If you transform this field into the frame of the electron, the field gets an electric component, leading to the same force.
Yes, this makes sense, and I know I can think of it either as purely magnetic (Earth's frame) or as an electric field (electron's frame). I thought the electron's frame would be easier but it hasn't been.
Then to me it seems that perhaps the converging of the magnetic field lines might help to explain why the parallel component of the velocity is lost, but I'm still having trouble.
The parallel component is not lost, but it can get reduced if the field strength increases, or the particle collides with other particles.
Yes, but what is the physics behind the reduction in the parallel component? Why does it reduce?
I found http://faculty.uml.edu/cbaird/95.657%282012%29/Ionosphere.pdf, which explains it well in terms of a dipole, but perhaps there's an explanation in terms of just the particle?
Increasing field strength correspond to an "inwards" component of the magnetic field (into the spiral). The velocity component orthogonal to this component gives a net force backwards, if I rotated those coordinates correctly.
  • · Replies 20 ·
  • · Replies 23 ·
