What is the functionality of the LM3914V driver?
  • Thread starter Thread starter GUOJINMIAO
The LM3914V driver is a specialized integrated circuit designed to control 10 LEDs based on linear input voltage values, functioning similarly to a VU meter or as a set of window comparators. It can operate in two modes: bar mode, where all LEDs light up in sequence, and dot mode, where only one LED is activated at a time corresponding to the input voltage range. The chip utilizes a string of comparators with reference voltages generated by a resistor divider, allowing it to compare the input voltage against these references. The datasheet provides detailed schematics and operational insights into the LM3914V's functionality.
  • Understanding of LM3914V functionality and modes (bar and dot)
  • Familiarity with comparator circuits and voltage reference generation
  • Knowledge of basic electronic components, including resistors and LEDs
  • Ability to interpret datasheets and circuit schematics
  • Review the LM3914V datasheet for detailed specifications and application circuits
  • Explore comparator circuit design principles and their applications
  • Learn about LED driving techniques and power management for LED displays
  • Investigate alternative LED driver ICs and their comparative advantages
Electronics engineers, hobbyists working on LED display projects, and anyone interested in understanding LED driver circuits and comparator functionality.
GUOJINMIAO
TL;DR
LM3914V is a chip that drives 10 LED-based on linear input voltage values.
Hi , all!
The LM3914 can light all LEDs/activate all outputs on a rising input similar to a VU meter kind of thing or function more like a set of window comparators and only light one LED/activate one output at a time, e.g. 1V to 2V input is only output 1 on, 2V to 3V input is output 2 on but 1 off, 3V to 4V input is output 3 on but 1 and 2 off, and so on. Is it right?
But I tried to think about it, Maybe parallel comparators referenced to the next reference voltage up or something? An enable/high Z pin on the comparators in the simplified schematic? Bar mode is easy to simulate, it's the same circuit as the simplified schematic.
Do any amazing people know about this? Thanks
[Moderator Note: Post has been edited to delete a questionable link. Here is a more generic link to the datasheet]
https://www.ti.com/product/LM3914?keyMatch=LM3914
GUOJINMIAO said:
Summary:: LM3914V is a chip that drives 10 LED-based on linear input voltage values.
Hi , all!
Thehttps://www.utmel.com/components/lm3914v-driver-alternatives-pinout-datasheet?id=328 can light all LEDs/activate all outputs on a rising input similar to a VU meter kind of thing or function more like a set of window comparators and only light one LED/activate one output at a time, e.g. 1V to 2V input is only output 1 on, 2V to 3V input is output 2 on but 1 off, 3V to 4V input is output 3 on but 1 and 2 off, and so on. Is it right?
I think the chip has a string of comparators and the reference for each is taken from a string of resistors forming a potential divider across the supply. I think the data sheet gives the schematic. I found the bar graph display a bit power hungry and also tended to be unstable. I have used both the linear version and the log version, and I have also used the chip as an A to D converter to demonstrate pulse code modulation using 4 bit coding.
A column of series resistors provide reference voltages spaced between Rhi and Rlo.
Comparators check the input voltage Vin, against all the reference voltages.
In one LED only mode, the digital outputs of adjacent comparators go to XOR gates that turn on the LED where the comparator outputs are different. Rather than a bar, that will show only one LED on.
Likes Tom.G and dlgoff
10K
  • · Replies 19 ·
15K
