Turbine performance: understanding notation
The discussion focuses on understanding turbine performance specifications, particularly the terms GT12, 72 Trim, and 0.39 A/R. GT12 refers to the model of the turbine, while 0.39 indicates the area-to-radius ratio. The 72 Trim designation is related to the design of the turbine wheel, impacting its performance characteristics. Additionally, the user seeks guidance on generating a corrected mass flow rate versus pressure ratio curve for a two-wheel bootstrap air cycle machine under varying flight conditions, despite lacking standard data at STP. The conversation emphasizes the importance of understanding these specifications for accurate performance analysis.
Rahul Mohan P
Hi Guys. This is for my post graduation project. I came across a turbine performance map where the turbine specs are mentioned as GT12, 72 Trim, 0.39 A/R. Now what exactly these terms means. Please help.
zAbso said:
http://turbobygarrett.com/turbobygarrett/wheel_trim
This should explain what trim is, I only briefly read over it but it should help.
Thank You. I have data for a two wheel bootstarp air cycle machine used in aircraft environmental control system for air-conditioning under working conditions. The data is for different flight conditions, different temperature and pressure. I want generate corrected mass flow rate vs pressure ratio curve of the turbine used in the system. I don't have the standard data noted at STP (standard pressure and temperature) conditions, and no manufacture provided performance curve, but can I generate a curve using the available values which is not taken under STP conditions.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
