Tweak TV Remote: Reduce Volume Automatically
  • Thread starter Thread starter RAJ917
The discussion centers on modifying a TV remote or the TV itself to limit the volume output, specifically aiming to keep the volume at a maximum of 12 while displaying 100. Participants suggest various methods, including physically altering the remote or TV, and highlight the challenges of modifying TV software. A practical solution mentioned is to put a resistor in series with the TV loudspeaker to effectively reduce the maximum volume output.
  • Understanding of basic electronics and soldering techniques
  • Familiarity with TV remote control functionality
  • Knowledge of audio signal processing
  • Experience with modifying electronic devices
  • Research methods for modifying TV software and firmware
  • Learn about resistor values and their impact on speaker output
  • Explore DIY electronics projects involving remote controls
  • Investigate safe soldering practices for electronic modifications
Electronics enthusiasts, DIY hobbyists, and anyone looking to control audio output levels in home entertainment systems.
RAJ917
I have a big problem at home. My brother puts the tv at high volumes. He doesn't reduce it when asked to. So now i have a plan to tweak with the remote or the tv itself. My plan is to modify something with the software of the remote so that the actual volume level of the tv remains to 12 even when it shows 100.
Get knife, dig out volume up button.
Or hit him with the remote until there is compliance.
I believe in brain power than muscle power.
I believe that Chris' answer was a perfect example of that. The bashing is merely a backup plan in case the dipgarbage doesn't realize your intellectual superiority.
You could also just unplug the TV.
I don't mind my brother watching the tv but without disturbing anyone. Especially when i am studying hard.
Well... if you don't want to hear it at all, as opposed to just at reduced volume, you could demonstrate your brotherly love by gifting him a set of headphones. All modern TV's have jacks for them.
I thought of this earlier but my brotherly love also cares about his ears too.
Sorry, man, but you're just getting way too picky for me. The only two options that I see being practical are to give him headphones or kill him. Given the price of headphones, I know which one I'd go with...
Oh come on there should be a way to tweak with remotes.
As far as I know remotes are very simple broadcast only devices. The remote doesn't know what volume the TV is at, and will continue to broadcast the volume up signal as long as the button is pressed. The TV is where all the software is. The TV knows what volume it is at, and what is its max volume. It also decides what to display on the screen.
I'd imagine editing the software running on the TV would be quite difficult, as I'm sure they don't make it easy to modify. You'd probably have to program a new chip and solder that in.
You could possibly modify a remote to keep track of the volume level and stop at a certain level. However this would have some problems. First, it wouldn't affect the display on the TV, so it would just stop at some point. Second, using the buttons on the TV would still work, and worse would mess up the remotes internal count of what the current volume is at.
The easy way would be to modify the TV so the "max" volume was quiet enough for you.
Putting a resistor in series with the TV loudspeaker would be a quick, cheap, and effective way to do that.
  • · Replies 25 ·
  • · Replies 26 ·
