Twin Paradox: Anne & Joe's 20th Birthday
The discussion revolves around the Twin Paradox involving twins Anne and Joe, focusing on the effects of relativistic travel on aging. The problem is divided into three parts: Joe traveling at a constant speed and then with acceleration, and the implications for their ages on significant birthdays.
  • Mixed
  • Participants explore the implications of special relativity on aging, particularly through calculations involving time dilation and the Lorentz factor. There are attempts to integrate velocity as a function of time and questions about how to properly set up the integrals for varying conditions.
Some participants have provided guidance on integrating the velocity function and determining constants, while others are questioning the assumptions made regarding acceleration and its effects on aging. There is acknowledgment of differing results between parts of the problem, indicating a productive exploration of the concepts involved.
Participants note the complexity introduced by Joe's acceleration and the need to reconcile different interpretations of time experienced by the twins. There is an ongoing discussion about the relationship between acceleration and velocity, as well as the implications for the aging process in the context of special relativity.
jazznaz
Anne and Joe are twins, happily living in an inertial frame. On their 20th birthday Joe decides
to take a rocket.
(a) According to Anne the rocket moves with constant speed [tex]v = \frac{3c}{5}[/tex]. For 6 months it moves away from Earth and then returns in time for Anne's 21st birthday. How old is Joe on Anne's 21st birthday?
(b) According to Anne the rocket is initially at rest and then accelerates such that its velocity is always proportional to [tex]\sqrt{t}[/tex], where t is the time elapsed since the start of the trip. After two years the rocket reaches a velocity of 3c/5. How old is Joe on Anne's 21st birthday?
(c) Joe is on his trip, according to (b). How old is Anne on Joe's 21st birthday?
[tex]d\tau = \int^{t_1}_{t_0} \frac{dt}{\gamma\left(v\left(t\right)\right)}[/tex]
For part a, I have,
[tex]d\tau = \frac{dt}{\gamma}[/tex]
[tex]\gamma = 5/4[/tex]
[tex]dt = 1\text{yr}[/tex]
[tex]d\tau = 4/5 \text{yrs}[/tex]
So Anne has aged one year, and Joe has aged 4/5 = 0.8 years. So Joe is about 20 yrs and 292 days old.
For part b I'm having trouble getting my head around how to incorporate the time dependence of the velocity into the integral (which is what we have been led into doing). I'm not sure whether to use the proper acceleration or to try to evaluate the integral as it is.
Any pointers would be greatly appreciated.
Just integrate the integral as it is. You have that [itex]v(t)=k\sqrt{t}[/itex] where k is a constant, so you can find [itex]\gamma[/itex] as a function of time t.
I've given that a go and I've ended up with an expression in terms of the speed of light and some constant. My best guess from here is to use the information in the question to try and determine what this constant is in terms of how it relates to the acceleration of the rocket?
EDIT:
Ok, for part b,
[tex]v = k\sqrt{2}[/tex]
[tex]d\tau = \int^{t_1}_0 \sqrt{1 - \frac{k^2 t}{c^2}}\, dt[/tex]
[tex]d\tau = \frac{2}{3k^2}\left( c^2 + \left(k^2 - c^2\right) \sqrt{1 - \frac{k^2}{c^2}}\right)[/tex]
So, now to determine what k is. I had a bit of a think about the relationship between acceleration and velocity, and used the usual relationships from calculus to do this, (?!)
[tex]\int^t_0 a \, dt = v +c[/tex]
Using a bit of reverse math,
[tex]a = \frac{3c}{10\sqrt{2t}}[/tex]
Since then,
[tex]\int^2_0 \frac{3c}{10\sqrt{2t}} \, dt = \frac{3c}{5}[/tex]
Which is the velocity as defined in the problem statement. From here we integrate a to determine the velocity, complete with constant of proportionality,
[tex]\int \frac{3c}{10\sqrt{2t}} \, dt = \frac{3c\sqrt{t}}{5\sqrt{2}}[/tex]
[tex]k = \frac{3c}{5\sqrt{2}}[/tex]
Now sub back into the original expression above to find,
[tex]d\tau = 0.953[/tex]
Quite different to the answer to part a, but what we would expect, no? Lower average velocity, so therefore the difference in time as perceived by the twins is less than before?
You also made solving for k way harder than you had to. You have an expression for v(t), so set v(2)=3/5 c and solve for k. You did get the right answer for k, though.
You seem to have made a mistake in the first integral. For one thing, t1 doesn't appear in your result. I think if you figure that out, you'll get the right answer.
Sorry, I've taken t1 to be the elapsed time interval that we are interested in, and that happens to be 1 year, so t1 is just 1.
Ah, okay. I see you also got a new numerical answer, which agrees with what I found. Your reasoning is correct. Joe is moving more slowly, so he ages more during the trip than when moving at a constant speed of 3/5 c.
Ahh great, nice to know that I'm getting the hang of this course - just about! Thanks very much for your help!
In regards to part c, can you just consider in joes frame that anne is moving and thus anne will have aged more slowly, giving t=0.953 as in part b?
I don't think so because the rocket's accelerating messes things up. I'll have to think about this a bit.
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 137 ·
11K
  • · Replies 27 ·
  • · Replies 115 ·
9K
