- 150
In order to avoid confusion, I have been using the terminology that you specified in your first post. I don't know what you mean by observer. Originally, you said there was going to be just "one observer and two apparatus". Then you called that one observer the coordinator. That's the terminology that I have consistently used and I have further identified the coordinator as being blue in my drawings. You also identified the "two apparatus" as two boxes which I have identified as red and green. But then you introduce two more observers to go with the two boxes. Now we have three observers and I have no idea what you mean by the statement:Trojan666ru said:Well your spacetime diagram is a good example that there's no paradox but logic still contradicts.
The root of the solution starts from the simultaneity. You have drawn that diagram assuming the moving box receives the signal way before the observer receives the signal
"You have drawn that diagram assuming the moving box receives the signal way before the observer receives the signal"
Each moving box receives only one signal in my diagrams and that signal is sent by the coordinator so who is the observer that you are referring to in the above quote that also receives the signal?
If you want to make charges that "logic still contradicts", you really should present your case in a logical manner and not force us to read your mind. I, for one, can't do that.
I have no idea what you have in mind. If I just read what you wrote, you are describing a scenario that looks like this, correct?Trojan666ru said:So i decided to solve it from the simultaneity part
From the unboxed (blue line) observers frame each travelers receive the signals simultaneously.
There's a setup here
After receiving the signals, it reflects towards a beam joiner which is placed at the centre and that beam is sent to the box1’ interferometer (Red box) .
You have to first tell me if I drew the spacetime diagram according to what you had in mind. I think I drew it according to my best understanding of your description.Trojan666ru said:Since according to the unboxed observers frame of reference, they must meet at the beam joiner and hit the interferometer simultaneously, therefore there won't be an interference pattern.
But when you apply simultaneity, from the red box’ point of view, the other one (green box) has already received the signal and therefore the light beams won't reflect simultaneously and will definitely form an interference pattern.
Solve this first.
If you can draw this in spacetime diagram, then it means it contradicts with logic
