Two balls carrying the same charge
  • Thread starter Thread starter jgridlock
    Balls Charge
The discussion revolves around a problem involving two balls carrying the same charge, focusing on the forces and energies at play as they interact. The subject area includes concepts from electrostatics and energy conservation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the relationship between force and energy, with some suggesting a focus on energy conservation rather than force calculations. Questions arise about the types of energy involved, including gravitational potential energy and kinetic energy. There is also discussion about the correct setup for equations and the implications of friction on the system's behavior.
Participants are actively engaging with the problem, offering guidance on energy conservation and the relevant forms of energy. There is a productive exploration of the total mechanical energy and its conservation, with some participants clarifying the relationship between different variables and their units. The discussion is ongoing, with multiple interpretations being considered.
There are constraints regarding the units used for calculations, and participants are encouraged to ensure consistency in their measurements. The problem also involves assumptions about the behavior of the balls when friction is introduced, which remains a point of inquiry.
jgridlock
The entire problem is in the attachment.
F = k*(|q||q0|)/(r^2)
F = 8.99e9(.450uC*.450uC)/(3cm^2) = 6.068e8
This problem has me completely lost and I am turning to you guys as my last resort. I solved for F and have no idea what to do after this. Any sort of insight would be appreciated and I can provide formulas upon request. Thank you.
Think in terms of energy, not force, for most of the questions.
I could use a little more guidance than that. What kind of process should I follow to solve part A?
Apply conservation of energy. What forms of energy are relevant here and how would you calculate them?
PE = mgh?
jgridlock said:
PE = mgh?
OK, that's gravitational PE.
What other kinds of energy are involved here?
Kinetic energy? KE = 1/2mv^2
Yep, that's another.
Keep going.
I wouldn't know any others. A guess would be charge?
Due to their electric field, those charges will have electric potential energy. Look it up!
Electric Potential Energy: PE = k((q1*q1)/r)
A pair of point charges separated by a distance
You may also want to check the units you are using for r.
Convert cm to m. 3cm = .03m
And g to kg. 12g = .012kg
Alright, next step?
Good!
Now see if you can come up with an expression for the total mechanical energy.
TME = 1/2mv^2+mgh+k((q1*q1)/r)
Good. But use the same distance r for both gravitational and electrostatic PE.
So your saying that both h and r should be .03m? And I am solving for velocity?
1/2(.012)(v^2) + (.012)(9.8)(.03) + (8.99e9(.45uC*.45uC)/(.03))?
I would use r for both, where r is the distance between the centers of the balls.
What's the velocity at the initial position? And at the highest position? (You're solving for that highest position.)
You'll take advantage of the fact that the total mechanical energy remains constant. Evaluate it at the initial position.
Okay so the r is going to be equal to .06m.
The velocity at the initial position is zero, so I set v = 0?
1/2(.012)(0) + (.012)(9.8)(.06) + (8.99e9(.45uC*.45uC)/(.06)) = .03739725
Yes, at the initial position.
Right.
I didn't check your arithmetic, but that's the right idea. Now set up a general equation and solve for the value of r at the final position.
So the number I just calculated is for the TME at r initial?
Thanks for all the help, sorry I need so much support.
Should the new equation be:
1/2(.012)(0) + (.012)(9.8)(.06) + (8.99e9(.45e9*.45e9)/(r)) = .03739725
Where I solve for r?
Yes, but since TME is conserved it is the value for any r.
Almost. But don't plug in any values for r. (Like your second term.)
(And make sure you use the right charges. .45μC = .45e-6C, not .45e9C.)
Alright, my final question is about the non mathematical part. Letters b-f (Correct me if I am wrong). When the balls are released the top one should reach a max height and then float above the second one because they repel each other. But then what happens when the friction comes into play?
I'd say that the top ball will reach a max height then fall back down to the lowest point again. It will keep oscillating, as energy is conserved.
Eventually friction will dissipate the energy and the ball will end up at some equilibrium position.
This depends upon the height of the cylinder versus the equilibrium position of the top ball.
It may continue to oscillate above the cylinder.
Good point.
9K
