Two blocks on an Incline w/ Friction
The problem involves two blocks sliding down a 20° incline, connected by a string, with given masses and coefficients of friction. The objective is to determine the acceleration of the blocks and the tension in the string.
  • Mixed
  • Participants discuss the forces acting on the blocks, including gravitational and frictional forces, and how to apply Newton's second law to find acceleration.
  • There is uncertainty regarding the correct mass to use when calculating the acceleration and tension.
  • Some participants suggest isolating one block to analyze the forces acting on it for tension calculation.
  • Questions are raised about the configuration of the blocks and the implications for tension in the string.
Participants are actively engaging with the problem, verifying calculations, and exploring different approaches to find the acceleration and tension. Some guidance has been provided regarding the use of free body diagrams and the application of Newton's laws, but no consensus has been reached on the final answers.
There is a lack of a visual figure to clarify the arrangement of the blocks, which may affect the understanding of the problem setup. Participants are also navigating potential errors in calculations and assumptions about the system dynamics.
dragonladies1
Two blocks attached by a string (see figure) slide down a 20° incline. Block 1 has mass m1 = 0.65 kg and block 2 has mass m2 = 0.30 kg. In addition, the kinetic coefficients of friction between the blocks and the incline are 0.30 for block 1 and 0.20 for block 2.
(a) Find the magnitude of the acceleration of the blocks.
m/s2
(b) Find the tension in the string.
N
Where do I go from here?
Mass 1
Fg=9.81*.65=6.38 N
Fgx= Fgsin(20)
=6.38sin(20)=2.18 N
Fgy=Fgcos(20)
=6.38cos(20)= 5.995 N
Fkinetics=mk*FN
=.3*5.995=1.7985 N
Mass 2
Fg=9.81*.3=2.94 N
Fgx=2.94sin(20)=1.006 N
Fgy=2.94cos(20)= 2.76
Fkinetics= .2*2.76= .552 N
I believe I have all of the numbers needed, I just do not know how to solve for the answers using these numbers.
Your numbers look good, so now first look at the 'system' of blocks and identify the magnitude and direction of all the external forces acting on the system in the direction parallel to the incline (you've already identified their magnitude). Then apply Newton's 2nd law to get the acceleartion. Then give a shot at finding the cord tension, using a free body diagram of one of the blocks to identify the forces acting on the individual block in the x direction.
Would it be:
1.006+2.18-.552-1.799=max?
I'm not sure what to use for the mass...would it be .65+.3?
dragonladies1 said:
Would it be:
yes
Yes again. When you look at the system of the blocks, you must use the total mass of both. When you isolate just one of the blocks (as you must do for part b), then use the mass of that block alone to solve for the tension force in the cord connecting the 2 blocks.
Don't forget your units.
I got:
ax=87.9 m/s2
But I have no idea what the equation is for tension...
I'm guessing the second block is hanging over the triangle i.e. it's hanging vertically downward.
The way to solve for tension is to ask yourself two questions:
1.) If you removed the block hanging down vertically from the system - what would the tension be? What does this answer tell you about what's contributing to the tension in the rope?
2.) If the tension in the rope wasn't the same everywhere, i.e. if there was a force in the rope, that would imply the rope had acceleration wrt to itself, but this isn't the case: what does that imply about the tension force all along the rope?
dragonladies1 said:
I got:
ax=87.9 m/s2
Your math is off by a factor of 100:
1.006+2.18-.552-1.799=m(a_x)
0.835 = 0.95(a_x)
a_x = 0.879 m/s^2
a_x = 0.88 m/s^2 (2 significant figures)
Isolate one of the blocks in a free body diagram; what forces act on that block in the x direction parallel to the incline? (the tension force will be one of them). Then use Newton 2 applied to that block alone, noting that it's acceleration is the same as the acceleration of both blocks together, as long as T comes out to be a positive number. If T comes out negative, it's a whole new ballgame. Which block is which...you don't have a figure...which one is toward the bottom of the incline??
  • · Replies 27 ·
10K
  • · Replies 19 ·
  • · Replies 23 ·
