Two Closed Thermodynamic Cycles Conceptual Question
The discussion focuses on the comparison of heat energy transferred to a gas during two closed thermodynamic cycles, specifically Cycle 1 and Cycle 2. It establishes that the work done during a clockwise process (W_clockwise) is greater than that during a counterclockwise process (W_counterclockwise). The conclusion drawn is that Q_clockwise for Cycle 1 is equal to Q_clockwise for Cycle 2, as both cycles yield the same net work done when processed clockwise. The relationship ΔU = Q - W is emphasized, confirming that the net heat transfer equals the net work done in a closed cycle.
  • Understanding of thermodynamic cycles
  • Familiarity with the first law of thermodynamics
  • Knowledge of work and heat transfer in thermodynamic processes
  • Basic mathematical skills for interpreting equations
  • Study the first law of thermodynamics in detail
  • Explore the implications of clockwise and counterclockwise cycles in thermodynamics
  • Learn about the properties of closed thermodynamic systems
  • Investigate the relationship between work and heat in various thermodynamic processes
Students of thermodynamics, engineers working with thermal systems, and anyone interested in understanding the principles of energy transfer in closed cycles.
doggieslover
Imagine processing the gas clockwise through Cycle 1 and then counterclockwise through Cycle 1. Compare these two processes on the basis of the heat energy transferred to the gas in the entire cycle.
Choose the correct comparison symbol.
Q_clockwise for Cycle 1 <,=,> Q_counterclockwise for Cycle 1.
So I know that W_clockwise for Cycle 1> W_counterclockwise for Cycle 1. and Delta U = Q - W
so is it > ?
Imagine processing the gas clockwise through Cycle 1 and then clockwise through Cycle 2. Compare these two processes on the basis of the heat energy transferred to the gas in the entire cycle.
Q_clockwise for Cycle 1 <,=,> Q_clockwise for Cycle 2
I know that W_clockwise for Cycle 1= W_clockwise for Cycle 2
so Would the answer be Q_clockwise Cycle 1 is equal to Q_clockwise Cycle 2?
You know that the net work done by the gas is positive when the cycle is clockwise (CW) and negative when the cycle is counterclockwise (CCW). Since ##\Delta U = 0## over a closed cycle, it follows that ##Q_{\text{Net}}=W_{\text{Net}}## regardless of whether the cycle is CW or CCW. However, those two equal numbers are both positive in the CW case and both negative in the CCW case. Thus, $$Q_{\text{Net,CW}}=W_{\text{Net,CW}}>Q_{\text{Net,CCW}}=W_{\text{Net,CCW}}$$because positive numbers are greater than negative numbers. It also follows that $$Q_{\text{Net,CW}}=W_{\text{Net,CW}}=|Q_{\text{Net,CCW}}|=|W_{\text{Net,CCW}}|.$$
