Two-Dimensional Projectile Motion: Finding Vertical and Horizontal Distances
The discussion focuses on solving a projectile motion problem involving a ball thrown at a 53-degree angle towards a 6-meter tall building. The initial horizontal and vertical velocities are given as 18.1 m/s and 3.42 m/s, respectively. To find the vertical distance the ball clears the wall, users are advised to calculate the maximum height using kinematic equations. For the second part, the horizontal distance from the wall to where the ball lands on the roof can be determined by calculating the total range and subtracting the initial distance of 24 meters from it. The conversation emphasizes the application of kinematics and trigonometry to solve the problem effectively.
philok
a ball is thrown up to the top of a building 6 m tall. It is thrown at a 53 degree angle above the horizontal at a point 24m from the base of the building. The ball takes 2.20s to reach a point vertically above the wall.
a) find the vertical distance by which the ball clears the wall.
b) find the distance from the wall to the point on the roof where the ball lands
Kinematics and other trig equations.
I know that Vx is 18.1 m/s and Vy is 3.42 m/s. From there I am not sure where to go. I have tried several different things and I am not coming up with the answer. Please tell me how to go about this problem to see if I am headed in the right direction.
Thanks.
are you given the initial velocity when the ball thrown?
Sorry about that. No It does give it. So that was my first step.
in the x- direction the intial velocity is 18.1 m/s and the y direction is 3.42.
That was suppose to be *doesn't give it.
assuming that you got Vx and Vy correctly, part (a) is asking for the maximum vertical height ,hint : what happens when the ball reaches maximum height? ( you can i.e use this equation y = voyt + 0.5gt^2 , g here as a vector quantity) ..
and part(b) is asking for the distance from the wall to the point on the roof where the ball lands, you can start this part by first finding the range of the travel (max. horizontal distance) and whatever you get from there subtract it the 24m from it .. can you go from there?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
