Two equivalent statements of time reversal symmetric Hamiltonian
  • Context: Graduate
  • Thread starter Thread starter hokhani
The discussion centers on the equivalence of two conditions for time reversal invariant Hamiltonians: the commutation relation ##[H,\Theta]=0## and the condition ##H=H^*##. Participants explore the implications of these conditions in different representations, particularly in position and momentum space, and the nuances involved in their definitions and applications.
  • Some participants assert that time reversal invariant Hamiltonians must satisfy the commutation relation ##[H,\Theta]=0##, while others reference the condition ##H=H^*## as an alternative formulation.
  • A participant notes that in Fourier space, the condition ##H(-\mathbf k)=H^*(\mathbf k)## is equivalent to time-reversal invariance.
  • There is a discussion about the representation of the Hamiltonian, with some participants emphasizing that ##H## should be treated as an operator rather than a function of variables.
  • Concerns are raised about the notation used in the referenced text, suggesting that the authors may be misusing the concept of complex conjugation when discussing operators.
  • One participant highlights the need for the Hamiltonian to be diagonal in a specific basis to relate the conditions properly.
  • Another participant questions the meaning of terms like ##\nabla_r^*## in the context of operators, suggesting that complex conjugation should only apply to numerical values.
  • References to external notes and alternative texts are provided to support various viewpoints on the topic.
Participants express differing views on the equivalence of the two conditions for time reversal invariance, with no consensus reached on the proper interpretation or notation. The discussion remains unresolved regarding the implications of these conditions in different contexts.
Participants note that the definitions and implications of the Hamiltonian's representation can vary, leading to potential ambiguities in the discussion of time reversal symmetry. The relationship between the conditions may depend on the specific basis used and the properties assumed for the time reversal operator.
hokhani
TL;DR
How ##[H,\Theta] =0## is equivalent to ##H=H^*##?
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
hokhani said:
TL;DR: How ##[H,\Theta] =0## is equivalent to ##H=H^*##?
Be careful, what is the argument? If you write ##H(t)## or ##H(\mathbf r)## it is not the same as ##H(\mathbf k)## (##\mathbf k## being the momentum/wavenumber). In Fourier space ##H(-\mathbf k)=H^*(\mathbf k)## is an equivalent condition to time-reversal invariance.
From the Eq. (7.18) in that text, it seems that by ##H## the authors mean the Hamiltonian in the position space. Also, as I remember, it was discussed previously in one of my last threads that ##H## is an operator and writing in the functional form ##H(variable)## doesn't make sense.
Sorry this gets confusing because we mix various stuff in second quantization, your ##H## is in some basis, let me use hats for operators. When I write ##H(\mathbf k)## I mean that you can write the usual Hamiltonian as ##\hat H=\sum_k \hat{c}^\dagger_k H(k) \hat{c}_k## with some creation operators ##\hat c^\dagger_k##. Note that ##H^*## makes no sense if ##H## is an operator.
Thanks, it was the key point here. If we work in the basis ##|q\rangle## where ##\Theta |q\rangle =|q\rangle##, then we have:
##\Theta H |\rangle=\sum_q H_q^* \langle q|\rangle^* |q\rangle## and
##H\Theta|\rangle=\sum_q H_q \langle q|\rangle^* |q\rangle##
so, ##[H,\Theta]=0## corresponds to ##H_q=H_q^*## and vice versa.
For that your Hamiltonian has to be diagonal in ##q##. Also you are assuming properties of ##\Theta## if not I don't get how are you getting the complex conjugate, maybe I am missing a step.
Right, since in that text the Hamiltonian were represented in position space where ##H_r## is diagonal, I implicitlly assumed diagonal q-representation for ##\hat{H}## as well as properties of ##\Theta##, ##\Theta(c|q\rangle)=c^*|q\rangle##.
Please copy the Hamiltonian here to understand your question better.
Eq. (7.18) in the text, introduces the time reversal dependent Hamiltonian as: ##H\psi(r)=[-\frac{1}{2m}(\nabla_r+ieA)^2+V(r)]\psi(r)##. So, here ##H## is in the positon space as ##H=H_r=\langle r|\hat{H}| r \rangle.##
But this ##H## still seems like an operator what does ##\nabla_r^*## mean?
I think if we accept the complex conjugation only acts on the numbers there is no ambiguity in this term, because at least the explicit form of the operator is clear. In contrary, the form of ##H^*## is representation-dependent and while the representation is not specified, there is no sense of complex conjugation.
pines-demon said:
Look at this notes from Berkeley:
I think Bruus is abusing with the notation.
The notes you sent formalizes the time reversal in a nice approach in accord with Sakurai.
The many body book of Bruus is a good reference which covers condense matter topics. However, in spite of several editions it contains a few such problems. Do you know any other alternative text at this level?
Try Fetter&Walecka or Coleman.
  • · Replies 175 ·
27K
  • · Replies 125 ·
20K
19K
