Two identical, uniform, frictionless spheres
The discussion focuses on calculating the forces acting on two identical, uniform, frictionless spheres resting in a rigid rectangular container, specifically when the line of centers makes a 45° angle with the horizontal. The participants analyze the forces in both x and y components, applying Newton's laws and free body diagrams. The correct force from the left wall is determined to be W*sin(45°), with the relationship between the forces from the spheres and the wall clarified through algebraic manipulation. This problem-solving approach successfully leads to the resolution of additional related questions.
  • Understanding of Newton's laws of motion
  • Knowledge of free body diagrams
  • Basic trigonometry, specifically sine and cosine functions
  • Concept of equilibrium in physics
  • Study the application of Newton's 3rd law in multi-body systems
  • Learn how to construct and analyze free body diagrams for complex systems
  • Explore the implications of frictionless surfaces in physics problems
  • Investigate equilibrium conditions in static systems
Physics students, educators, and anyone interested in mechanics, particularly those studying forces in static equilibrium scenarios involving multiple bodies.
juggalomike
Two identical, uniform, frictionless spheres, each of weight W , rest in a rigid rectangular container as shown in the figure. Find, in terms of a ratio to W, the forces acting on the spheres due to the container surfaces and one another, if the line of centers of the spheres makes an angle of 45° with the horizontal. Normal force from the left side of the container?
[PLAIN]http://img260.imageshack.us/img260/7907/1368b.jpg
Newtons 3rd law(not really an equation)
Looking at the picture i believe the force from the left side of the container will be equal to the force in the x direction applied to ball 2 from ball 1, so i set the force to be W*cos45, however that is not correct.
Hello juggalomike,
What makes you say that the force in the x direction applied to ball 2 from ball 1 is Wcos(45o)?
collinsmark said:
Hello juggalomike,
I was originaly thinking of the ball is touching the other ball at a 45 degree angel then the components would be wcos45 and wsin45, however thinking about it the wall is also part of the equation, however i have no idea how to include that.
Okay, let's think about that. And let's ignore the wall just for the moment -- one can come back to it later (and yes, the wall does fit into things. But you can come back to that later anyway).
Let's break up the problem into its x and y components. I'll concentrate only on the y component for now. Gravity exerts a force on the top ball with a magnitude of W in the down direction. Since nothing is accelerating, something else must be acting on that ball with a force of W in the up direction. What is exerting that force? And if that force in the up direction is only the y component of some other total force, what is the magnitude of that total force?
A good way to solve problems like this is to start by drawing a "free body diagram." Nothing is moving, so you know all the forces involved in the y direction must cancel each other (everything is in a state of equilibrium). The same is true for all the forces in the x direction. Once you figure out the y forces involved, you should be able to use your free body diagram to find the x forces (the x forces involve the balls and the walls too).
alright i did as you said and for each ball here are the forces i calculated
ball1
x component----Fb2*cos(45)=Fw
y component----Fb2*sin(45)=W
ball2
x component----Fb1*sin(45)=Fw
y component----Fb1*cost45+W=Fn
Which would still meen the force from the left wall is W*sin(45). What am i doing wrong?
ball1
Okay, let's just start with ball 1 for now. You can come back to ball 2 later.
You have stated,
Now solve for Fb2. (Note that if a x b = c, then ab x c. Instead the correct relationship is, a = c/b).
So what do you have for Fb2? Now find
using your result for Fb2.
You have stated,
y component----Fb2=W/sin(45)
x component----Fb2=W/cos(45)
W/sin(45)=Fb2=W/cos(45)?
Well, the left side the equation is correct (the y component).
W/sin(45)=Fb2
But the x component deals with the force from the wall, not W (at least not directly). So now use the equation you already derived to show the force from the wall, in terms of Fb2.
Fb2cos(45)=Fw,
where Fw is the force from the wall. Using the two equations, solve for Fw in terms of W.
Thank you so much for the help, this was actualy an 8 part question(i only posted the 1st part). After ur last post i was able to figure out the other 7 parts within a few minutes.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 19 ·
