AbigailM
- 46
Two identical carts (of mass m) are free to move on a frictionless, straight horizontal track. The masses are connected by a spring of constant k and un-stretched length l_{0}. Initially the masses are a distance l_{0} apart with the mass on the left having a speed v_{0} to the right and the mass on the right at rest. Find the position of the mass on the left as a function of time.
I'll write the position of m_{1} as x and the position of m_{2} as y.
m_{1}=m_{2}
x(0)=0
\dot{x}(0)=v_{0}
q=y-x-l_{0} and its derivatives.
L=\frac{1}{2}m\dot{x}^{2}+\frac{1}{2}m\dot{y}^{2}-\frac{1}{2}k(y-x-l_{0})^{2}
Equations of motion for the Lagrangian
m\ddot{x}=k(y-x-l_{0})
m\ddot{y}=-k(y-x-l_{0})
Using q=y-x-l_{0} and \ddot{q}=\ddot{y}-\ddot{x}
\ddot{q}=\frac{-2k}{m}q=-\omega^{2}q
which has the solution
q(t)=Acos\omega t+Bsin\omega t
We also have equations in the form
\ddot{x}=-\omega^{2}x and \ddot{y}=-\omega^{2}y
Substituting the two previous equations into our equations of motion for the Lagrangian we find that
y=-x
Now we substitute y=-x into q=y-x-l_{0} and get
q=-2x-l_{0}
x(t)=-\frac{1}{2}q(t)-\frac{l_{0}}{2}
x(t)=-\frac{1}{2}Acos\omega t-\frac{1}{2}Bsin\omega t-\frac{l_{0}}{2}
\dot{x}(t)=\frac{\omega}{2}(Asin\omega t - Bcos\omega t)
Apply initial conditions
x(0)=0 so A=-l_{0}
\dot{x}(0)=v_{0} so B=\frac{-2v_{0}}{\omega}
So our solution is
x(t)=\frac{v_{0}}{\omega} sin\omega t + \frac{l_{0}}{2}cos \omega t - \frac{l_{0}}{2}
where \omega=\sqrt{\frac{2k}{m}}
Just to point out I set the initial position of the left mass at the origin as I figured all we need is the position information of the two masses relative to each other. Please comment on this if I did this wrong.
Is this solution close? As always thanks for the help!
