Two objects, and where they meet
  • Thread starter Thread starter ex81
The problem involves a worker pulling a box with a mass-less rope on a frictionless surface. The worker starts at rest and applies a constant force, with the goal of determining the position where the worker and the box meet, expressed in terms of the given variables.
  • Mixed
  • Participants discuss the application of Newton's laws and the relationship between the forces acting on the worker and the box. There are attempts to derive equations for their positions over time, but some participants question the assumptions regarding acceleration and the need for additional information about the forces involved. Others suggest considering the system as a whole or using concepts like center of mass.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have provided guidance on how to express the accelerations in terms of known quantities, while others emphasize the importance of understanding the relationship between the worker and the box. There is no explicit consensus on a single approach yet.
Participants note that the problem constraints limit the use of certain concepts, such as center of mass, unless explicitly provided. There is also a recognition that the lack of specific force values complicates the determination of acceleration for both the worker and the box.
ex81
A worker with a mass of Mw is pulling on a mass-less rope that is attached to a box with a mass of mb on a friction-less surface. The worker pulls with a constant force starting at rest. The Worker is at x = 0, and the box is at xb Find the position at which they meet in terms given.
x = xi + vi * t + 1/2 a * t2
F = m * a
Using Newton's laws I know that the force on each object is equal, so
Fw = Fb
xw f = xw i + vw i* t + 1/2 a * t2
thus for the worker's side of the equation
xw f = 1/2 a * t2
and the box moves
xb f = xb i + vb i* t - 1/2 a * t2
thus
xb f = xb i - 1/2 a * t2
since they meet xb f is equal to xw f
thus
1/2 a * t2 = xb i - 1/2 a * t2
xb i = 1/2 aw * t2 + 1/2 ab * t2
2 xb i = (aw + ab) * t2
t = √( ( 2 * xb i) / aw + ab)
then taking what I have just solved for time, and plugging that back into the basic kinematic equation to find the distance I get jibberish. So I'm not sure where to go from here.
xmeet = xinitial + 1/2 aworker * ( ( 2 * xb i) / aw + ab)
They don't have the same acceleration, do they?
But do you really need to go through this?
Have you learned about center of mass?
Okay, your approach could work eventually, but the problem is that you don't know what your acceleration is, since you aren't given the force with which the worker pulls. There's a simpler way to go about this though. Think about the worker-block system. Is the tension in the rope external or internal to this system?
Fw = Fb
Use F=m•a to determine the acceleration of each of the bodies.
fun mass calculations
I know the force on the person, and block is the same but I do not know the mass, or ratio of mass. So the closest I can get to knowing the constant accelerations is a = F/mworker/block depending on which mass is used.
While I know about the center of mass, it isn't something I am supposed to use. Nor would it be okay to use as it is not a given, or something simple as a kinematic equation.
That's right. The two bodies experience different accelerations.
If you don't use center of mass (by the way, you don't have to be "given" it to be able to use it) then your approach can work. However, with the answer you have you have it in terms of acceleration, but you want to have it in terms of only things given in the problem, so replace the accelerations by force and mass.
relative displacement and velocity concept would be nice here.
What would be the relative displacement of the man wrt the box, taking origin to be at the initial position of the man ?
@jack per the question I actually have to be given that to use it, or the answer is not correct. The whole if your method does not match it is not correct issue.
@phoenix The worker starts at x, which happens to be zero, and the box starts at x b. They meet at xf, and x box final(the same spot). Now this occurs at the same instant so the displacement of time delta T is therefore equal. My "solutions" just don't work.
Your solutions are OK now.
Just replace the accelerations in terms of the known masses.and the tension in the rope.
The tension will simplify.
  • · Replies 26 ·
  • · Replies 20 ·
