Two planes contain two non intersecting lines can be made parallel?
In three-dimensional space, any two non-intersecting lines can be contained within two parallel planes. This conclusion is established by generating vectors V1 and V2 parallel to each line, and then using the cross product V1 X V2 to derive a normal vector N, which serves as the normal for both planes. An alternative proof involves constructing the shortest line C between points on each line, demonstrating that C is perpendicular to both lines, thereby allowing the construction of two parallel planes perpendicular to C, each containing one of the lines.
  • Understanding of vector operations, specifically cross products
  • Familiarity with geometric concepts in three-dimensional space
  • Knowledge of perpendicularity in geometry
  • Basic principles of plane equations in 3D
  • Study vector cross product applications in geometry
  • Explore the properties of perpendicular lines and planes in 3D space
  • Learn about plane equations and their geometric interpretations
  • Investigate advanced geometric proofs involving non-intersecting lines
Mathematicians, geometry students, and educators looking to deepen their understanding of spatial relationships between lines and planes in three-dimensional geometry.
yungman
From the book, given any two lines non intersecting lines in 3 space, any two planes each contains one of the lines can always make parallel to each other ( the two planes are parallel).
The way the book described is that given two lines, you can produce two vectors V1 and V2, each parallel to one of the lines. Then by cross product V1 X V2, you get the normal vector N. The vector N is also the normal vector for both planes. Therefore the two planes are parallel.
Do you have a more convincing way to proof the two planes that contain the two individual non intersecting lines can be made parallel?
Here's a different way of looking at it.
Call the two lines A and B. You can draw a line from any point on A to any point on B.
Let C be the shortest line that you can draw from a point on A to a point on B. You should be able to see that C is perpendicular to A, and also C is perpendicular to B. (For example, if the angle between A and C was not a right angle, you could draw a shorter line, from the same point on B, but making the angle closer to a right angle).
You can draw two planes perpendicular to C, one containing line A and the other containing line B, and those two planes are parallel.
Thanks for the reply. So you can always draw two parallel planes, each contains one of the two non intersecting lines.
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 36 ·
  • · Replies 26 ·
