Efficient Pump Usage in Fuel Oil Supply System: Solving for Tank Fill Time
  • Thread starter Thread starter Girn261
    Pumps
The discussion focuses on calculating the fill time for Tank A in a fuel oil supply system using two pumps, Pump A and Pump B. Pump A fills Tank A in 920 minutes, while Pump B fills Tank B in 1050 minutes. When both pumps operate simultaneously, the fill time for Tank A is determined to be 490 minutes. However, when Pump A fills Tank A while Pump B transfers fuel from Tank A to Tank B, the calculated time is 7430 minutes, assuming equal tank volumes and differing pump capacities.
  • Understanding of fluid dynamics and flow rates
  • Basic algebra for solving equations
  • Knowledge of pump operation and efficiency
  • Familiarity with time conversion between hours and minutes
  • Research fluid dynamics principles in pump systems
  • Learn about flow rate calculations and their applications
  • Study the effects of simultaneous operations in fluid transfer systems
  • Explore pump efficiency metrics and performance optimization techniques
Engineers, fluid mechanics students, and professionals involved in fuel supply systems or pump operations will benefit from this discussion.
Girn261
A fuel oil supply system consists of two tanks (Tank A and Tank B) and two transfer pumps (Pump A and Pump B) to supply a Bunker C fuel oil to a heating boiler.
Pump A can fill up a Tank A from the minimum level in 15 hours and 20 minutes
Pump B can fill up a Tank B from the minimum level in 17 hours and 30 minutes
Calculate the time to fill up Tank A from the minimum level under the following conditions.
a) both pumps are used simultaneously
b) pump A is used to fill up Tank A while Pump B is transferring fuel out from Tank A to Tank B
for part a) I converted the hours to minutes for both pumps, I assume both tanks to be same size. Pump A = 920mins to fill tank & 1050 mins for pump B. Then I did (1/920+1/1050)x(t)=1 to find t which was 490 mins. But for part B any tips? I'm having a brain fart.
Consider what the change is over one minute.
Are the two tanks the same volume? Or are the two pumps of equal capacity? Neither? If neither seems like not enough info given.
Okay I am kinda lost haha. But I did this (1/1050-1/920)=1/x and for x I got 7430 mins. Is that right?
thats the exact question, so I think you're suppose to assume the tanks are same volume, while the pumps are different capacity
Yes.
Well, I think it's exactly badly phrased, :smile: but OK you have to assume something, might as well be equal-size tanks..
