Calculating slit separation for sound two-slit interference?
  • Thread starter Thread starter fwFAWFSERG
    Interference
The discussion focuses on calculating the slit separation distance for a two-slit interference setup that produces interference fringes for sound at a frequency of 262 Hz, analogous to red light at 4.9×1014 Hz. The established formula for this calculation is sin(theta) = m(wavelength)/d, where the wavelength is derived from the speed of sound (343 m/s) divided by the frequency. The correct slit separation distance calculated is 640 mm, confirming that the velocities of sound and light are distinct and must be treated accordingly.
  • Understanding of wave properties, specifically interference patterns.
  • Familiarity with the formula for wavelength: λ = v/f.
  • Knowledge of the speed of sound in air at room temperature (approximately 343 m/s).
  • Basic grasp of trigonometric functions related to wave angles.
  • Study the principles of wave interference and diffraction patterns.
  • Learn about the relationship between frequency, wavelength, and wave speed in different mediums.
  • Explore the mathematical derivation of the two-slit interference formula.
  • Investigate the effects of varying slit separation on interference patterns in sound waves.
Students in physics, acoustics researchers, and educators looking to deepen their understanding of wave interference phenomena in both light and sound.
fwFAWFSERG
SOLVED
A two-slit interference set-up with slit separation d =0.30 mm produces interference fringes at a particular set of angles THETAm (where m = 0, 1, 2,) for red light of frequency f = 4.9×10^14 hz.
If one wishes to construct an analogous two-slit interference set-up that produces interference fringes at the same set of angles THETAm for room-temperature sound of middle-C frequency f = 262 hz, what should the slit separation distance be for this analogous set-up?
this particular problems answer is 640 but i can't seem to arrive at that
sin(theta)= m(wavelength)/d
i believe sin(theta) is equalin both, so i don't see why it wouldn't come down to wavelenth/d is proprotional to wavelenth/d, or converting to frequency 1/fd = 1/fd or fd=fd.
You know \lambda = v/f, but they both have different velocities so you can't use fd = fd.
arent their velocities equal at c, being the speed of light?
Sound doesn't travel at the speed of light. At least not where I live at.
oh that is quite true, shouldn't have overlooked that, so i can now say the formula is
c/fd = 343/fd?
edit: yes i can, thanks a lot nickjer, i got it now.
  • · Replies 28 ·
