Two Spring System: Steady State Motion
  • Thread starter Thread starter mwkfun
    Spring System
mwkfun
Consider a system consisting of two springs suspended from the ceiling. The first has a spring constant k-1, the second k-2. They are connected by a mass m and the second spring also has a mass m connected at the bottom. A periodic force is applied to the upper mass. What is the steady state motion for each mass?
Fcoswt
x1 = Acos wt
x2 = Bcos wt
Welcome to PF!
Hi mwkfun! Welcome to PF! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
I tried two different ways...I attempted to turn the system into an electrical circuit equivalent and I tried with free body diagrams and the following equations:
mX=mg + k1x1 + k2x2 - Fcoswt
mX=mg + Fcoswt - k1x1 - k2x2
(For these two eqns. the X means X double dot indicating acceleration)
mX2 = mg + k2x2 - Fcoswt
mX2 = mg + Fcoswt - k2x2
(again, X2 indicates x double dot...I don't know how to type it the correct way)
I think I should be solving for x1 and x2, but I am not sure if I have the correct equations. The eqns. reflect the free body diagrams I have drawn. Thanks for any help you can give.
I am also wondering whether I should use the x1= Acoswt and x2 = Bcoswt as a substitutions or if they are specific solutions to the differential eqns.
mwkfun said:
… I tried with free body diagrams and the following equations:
Hi mwkfun! :smile:
(on this forum, it's best to use dashes instead of dots: X1'' :wink:)
I don't understand why you've put each of these equations in pairs :confused:
Anyway, you need to take into account that the displacement of the lower mass is not the same as the displacement of the lower spring … it's the displacement of the lower spring minus the displacement of the upper spring :smile:
Thanks so much for your help. I think I got it!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
