Types of transformers used in LCD backlights
  • Thread starter Thread starter KarlH
    Lcd Transformers
Piezoelectric transformers are not commonly found in computer LCDs, as most dismantled monitors utilized low-profile, high-voltage ferrite-cored transformers, particularly in CCFL backlit models. LED backlit monitors do not require high-voltage power supplies, which further reduces the likelihood of piezoelectric transformers being used. The discussion also touches on the variations in power supply configurations between CCFL and LED backlit panels. Additionally, there is interest in comparing piezo and magnetic transformers in terms of their potential interference in testing environments. The need for specific part numbers and datasheets for piezo transformers was also mentioned, indicating a desire for more technical information.
KarlH
How common are piezoelectric transformers in computer LCDs?
I don't know
None of the dozens of different types of LCD monitors I have dismantled have had piezoelectric transformers
they have all been the typical low profile high voltage low current ferrite cored transformers
Likes KarlH
davenn -- how many of those were CCFL backlit? I think that's the only type that would use piezo to create the high voltage. (I don't know the answer as to how often they are used in CCFL monitors)
Likes KarlH
just call me Dave :smile: ... I have used davenn as a user name all over the net since the early to mid 1990's the 2 x n's are the first and last letters of my surname
they were all CCFL, the LED backlit ones ( of which I have stripped dozens) of course don't need HV PSU's ... but what a wonderful source of strips of LEDs !
mite do a couple of pix tomorrow if I get a chance to show the transformers in the CCFL type I work on
Dave
Likes meBigGuy and KarlH
Thanks much :smile:
So panels with LED backlights run at the same voltage/amperage as the output from the AC/DC converter?
I was going to ask if anyone had a part number or two so that I could look up dimensions, but a picture would be even cooler :smile:
They have their own sub-PSU off the main PSU for the screen
there's just too many variations to do that
Oh, I didn't mean that at all.
I used to work in a laboratory that did a lot of spindle error motion testing using capacitance gauges. We were worried about errors in the low single digit nanometers (and sometimes low double-digit picometers), so EMI was a concern. Even when the target was buried in a probe nest made of 1-2" thick 414 stainless, we would often see a blip at 60Hz on the FFT.
A while ago I read an article comparing piezo and magnetic transformers in CCFL LCDs, and that made me wonder whether we were missing a source of interference in all of those tests (since it could be at a different frequency). The FFT cutoff was often set to 100Hz, since there hadn't been much beyond that in earlier tests, but if the internal PSU in the display that sat right next to the probe nest ran at a higher frequency, we would have been blind to it. (I'd be pretty embarrassed if that were the case.)
interesting, As far as I'm aware I have never seen a piezo type transformer
Just knowing that there will be magnetic transformers in the enclosure is a good start. Thanks.
does anyone have a datasheet for one of these single layer piezo transformers? specifically the SMSTF150P1S7
