EE Student: Ubuntu or Debian - What to Choose?
  • Thread starter Thread starter SuperMiguel
    Ee Ubuntu
For electrical engineering (EE) students deciding between Ubuntu and Debian, both operating systems are largely interchangeable, with nearly all applications installable on either platform. Ubuntu is recommended for those new to Linux due to its user-friendly nature and up-to-date repositories maintained by Canonical. While Fedora offers unique spins that bundle optimal applications for specific tasks, the consensus is that the choice between Ubuntu and Debian should be based on personal preference or departmental requirements. The only notable exception in application compatibility is Code::Blocks 10, which may have compatibility issues with Ubuntu's wxWidgets version.
  • Basic understanding of Linux operating systems
  • Familiarity with package management systems, specifically Debian packages
  • Knowledge of application installation processes on Linux
  • Awareness of different Linux distributions and their use cases
  • Research the differences between Ubuntu and Debian, focusing on package management and user experience
  • Explore Fedora spins and their applications for circuit design
  • Investigate the installation process of wxWidgets from source on Linux
  • Learn about the latest updates and compatibility fixes for Code::Blocks 10
Electrical engineering students, Linux newcomers, and anyone evaluating Linux distributions for academic or research purposes.
SuperMiguel
Im an EE student, should it run Ubuntu or Debian ??
Computer science news on Phys.org
It doesn't really matter, nearly everything installable on one is also installable on the other. In fact, I've only seen one example of an application that could run on one, but not the other, and it was an IDE, and therefore, irrelevant to you.
Have you used Linux before? If not, Ubuntu.
ya been a gentoo user for a while, but gentoo is becoming a pain in the a** having to do everything manually, so just wondering which would be better
For an ee student deb or ubuntu
Either, since it's the apps not the OS itself that contribute to it's usability for a given purpose.
That said, is there a reason you've not mentioned Fedora? Sometimes it can be hard to choose the right app(I've tried 3 for circuit design.). As I'm sure you know, usually, there's a lot of crappy ones that are all trying to be like the one good one. Fedora has an interesting fix for this, they have what are called spins, which bundle the best apps for a given purpose. I think one of their spins may interest you: http://spins.fedoraproject.org/fel/
Umnn never tough about fedora
any student?
I'm agreeing with everyone else: the different distros are more or less interchangeable, specially since ubuntu is http://www.ubuntu.com/community/ubuntu-and-debian. Since you're sick of doing things manually, ubuntu would probably be better 'cause Canonical tends to keep the repos pretty up to date. Otherwise, choose whichever one your department uses or better yet whichever your lab uses (if you're doing research.)
To add to what story said: I assumed it was understood, just in case I'll go ahead and throw it out there. They literally use the same package system. A Debian package can be installed on Ubuntu and vice versa. The ONLY exception to this that I know of is Code::Blocks 10 which uses a version of wxWidgets incompatible with Ubuntu's version. And it may have been fixed by now, idk.
Or you can just install wxWidgets from source and call it a day.
Not if you're tired of doing it the manual way. :-p
:) :-p
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 17 ·
