Uncertainty and significant figures
The discussion centers on determining the appropriate number of significant figures for a calculated speed of sound, which is 327.66 m/s with an uncertainty of ±3%. The correct answer is option C, 330 m/s, as it reflects the uncertainty in the second significant figure. The participants clarify that the uncertainty indicates confidence in the first digit and variability in the second digit, leading to the conclusion that the result should be expressed to two significant figures.
  • Understanding of significant figures and their rules
  • Basic knowledge of uncertainty and error analysis
  • Familiarity with rounding numbers correctly
  • Ability to perform calculations involving percentages
  • Study the rules for significant figures in scientific measurements
  • Learn about error propagation and its impact on measurements
  • Explore rounding techniques for significant figures
  • Review examples of calculating and expressing uncertainty in measurements
Students in physics or chemistry, educators teaching measurement concepts, and anyone involved in scientific data analysis who needs to understand significant figures and uncertainty in calculations.
songoku
A student makes measurements from which she calculates the speed of sound as 327.66ms–1. She estimates that her result is accurate to ±3 %. Which of the following gives her result expressed to the appropriate number of significant figures?
A 327.7ms–1 B 328ms–1 C 330ms–1 D 300ms–1
significant figures
The maximum value = 327.66 x 1.03 = 337.4898
The minimum value = 327.66 x 0.97 = 317.8302
How to proceed and how to take significant figures into account? I know that for multiplication, the answer should follow the least significant figures, but how to apply it here?
The solution is (C) and I don't how to get it.
Thanks
There are a number of ways of thinking about this, all of which arrive at the same conclusion.
The 3% uncertainty translates, as you point out, to a value where the uncertainty lies in the 2nd figure. (2nd from left)
337
317
This means that the best of the 4 alternatives is the one expressed to 2 significant figures. Option C.
330 m/s means that you are confident of the first figure (3) and the uncertainty lies in the 2nd figure (3)
328 m/s would mean you are confident in the 1st 2 figures (3 and 2) and the uncertainty is in the 3rd figure. the 8
300 m/s would mean the uncertainty lies in the 1st figure.
337
317
How can we know that the uncertainty lies in the 2nd figure?
The same question as above. How to determine the position of the uncertainty?
Thanks
significant figures
Thanks
Notice that the extreme answers are 10 either side of the calculated value. That means we know the answer to the nearest 10, so we express the answer rounded off to the tens figure.
If this is not multiple choice question, can I answer 320?
In a number, a digit is reliable iff the error is not bigger than 0.5 x positional value of the digit. A positional value is 10^{n - 1}, where n is the position of the digit on the left from the decimal point, and 10^{-n}, where n is the position of the digit to the right of the decimal point.
In your case, the double of the error is 10 < 20 < 100, so n = 3 is reliable, whereas everything to the right of it unreliable. You could have seen this by your writing answer with the upper and lower bounds. You see that the third digit remains unchanged.
Nevertheless, reliable and significant digit are not the same thing.
This article explains it quite well:
http://www.av8n.com/physics/uncertainty.htm#sec-execsum-sigfig
NO. That answer would indicate you are just leaving off / ignoring any figures after the last figure you deem accurate.
Of these figures:
300, 310, 320, 330, 340, 350
which one is closest to 327?
Hold on: the third digit remained unchanged, but the second digit did change !
so, what's your point?
I had not read your positional descriptions correctly
Sorry I don't find about positional value in the link and I also don't understand about positional value you said.
The error should not bigger than 0.5 x positional value of the digit. I think the error in the question is 10 since the upper and lower bounds are more or less differ by 10 from the actual value. So positional value of the digit must be bigger than 20
You take n = 3 because 20 < 100 = 10n-1, where n = 3. Then what does n = 3 mean? n is the position of the digit on the left from the decimal point, but I can't interpret what to do with n = 3
Of these figures:
What is the meaning of "any figures after the last figure you deem accurate"? Which 'last figure' are you talking about?
Thanks
Thanks
I agree with you that the uncertainty is ±10, therefore the "units" digit is unnecessary.
The number 327 can be rounded off to 3.3 x 102 sometimes written as 330
or as some people write, 3.2 x 102 sometimes written as 320.
This second answer means the all digits after the "tens" were ignored - which in this case gives and error.
I see lots of students who merely write down the first few digits that are displayed on their calculator, paying no attention to the next digit to see if the answer should be rounded up. They know the final answer should be expressed to 2 significant figures, but instead of rounding to 2 figures, they merely leave off everything except the first 2 figures.
I have even seen students express an answer like 32.97 as 32
When you suggested 320 as a possible answer, you were looking like one of those people who just drops off the unnecessary digits, rather than rounding correctly.
Ok, so first we find the error (uncertainty), which is ± 10, to decide where we should round the number. In this case, it is the "tens". The number will consist of "hundreds" and "tens", which means that we should express the final answer in 2 significant figures.
Am I getting the correct concept here? Thanks
That is correct - 2 significant figures. AND rounded off, not truncated. don't just leave off unwanted digits, round off correctly
That was why 320 was wrong. 320 is just 327 with the 7 ignored. 330 is 327 rounded off.
ok thanks a lot for your help :)
