Uncertainty for n using calculus
To find the uncertainty of n, the differentiation of the sine functions is essential, particularly using the quotient and chain rules. The user has already calculated the uncertainties for Dm and a, which are necessary for the calculations. The process involves computing the partial derivatives, specifically ##\frac{dn}{da}## and ##\frac{dn}{d(Dm)}##. The total uncertainty can then be determined by summing all the individual uncertainties. This approach will help clarify the steps needed to tackle uncertainty calculations effectively.
SHAWN JAMES
Hi, I need help ASAP with finding the uncertainty of n i've been trying for an hour to figure out how to tackle this question can I please have some guidance as to how to approach the question?!! Thanks in advance.
n=(Sin((Dm + a)/2))/(Sin(a/2))
i'm thinking of differentiating the inside of both sin functions but I'm not sure what to do with the sin. if anything, I'm new to this sort of uncertainty calculation. I have calculated the uncertainty and values for both Dm and a in advance.
I believe you first have to compute ##\frac{dn}{da}## and ##\frac{dn}{d(Dm)}## via a little quotient + chain rule. Then you can take the sum of all of the ##dn##'s.
SHAWN JAMES said:
Homework Statement:: Hi, I need help ASAP with finding the uncertainty of n I've been trying for an hour to figure out how to tackle this question can I please have some guidance as to how to approach the question?! Thanks in advance.
Relevant Equations:: n=(Sin((Dm + a)/2))/(Sin(a/2))
Hint: $$ df = \frac {\partial f } { \partial x} dx + \frac {\partial f } {\partial y} dy ~+ ... ~$$
where f = f(x,y, ...) and x, y ... are assumed to be independent variables.
Likes etotheipi
  • · Replies 20 ·
