Uncertainty in parameters -> Gauss-Newton
6 replies · 5K views · last reply
Or Entity?
Uncertainty in parameters --> Gauss-Newton
Hi guys!
I have a set of datapoints, and i´m about to use Gauss-Newton to fit a model function (Lorentzian) to these points. So we´re talking abut a nonlinear least squares regression.
How do I estimate error in function parameters given errors in data points?
Thanks.
EnumaElish said:
Simulation using pseudo-random number generation?
Nothing I'm familiar with. Could you develop?
Isn´t there any method equivalent to that using the covariance matrix in weighted linear least squares?
Allright, have read it through. Thanks
One thing though, where does the errors from my original data come in?
I will write vectors in bold, so for example y = {y(1), ..., y(i), ..., y(n)}.
In a proper bootstrap, you are just "mixing and matching" the errors you've already computed: y*(i) = y(i) + u(j), where j is "almost surely" different from i, u(.) are the computed errors, and y* is a convolution of y. This "remix" algorithm is repeated many times (say 100 times), so you have 100 different estimates of your model parameters coming from convoluted vectors y1*, ..., y100*.
In the approximate bootstrap (monte carlo?), you use the computed errors to derive the approximate "population distribution." Suppose the errors "look like" they are distributed normally with mean = 0 and standard deviation = s, i.e. u*(i) ~ N(0,s2). Then, you can use a pseudo-random generator to produce repeated draws from Normal(0,s2) and define y**(i) = y(i) + u*(i). Again, if you run this 100 times, you will have 100 parameter estimates from y1**, ..., y100**.
Amazing.. I was experimenting with a a method just like that one when I saw your reply.
Interesting method that can be applied to any linear/nonlinear method.
By the way since gauss-Newton linearizes the problem in each iteration I should get pretty decent results by making a weighted regression and taking the covariance matrix in the last step. (Like in linear least squares)
