Uncertainty Principle logic help
The discussion centers on whether the uncertainty principle contradicts the idea of an object being at rest relative to an observer. Participants clarify that the uncertainty principle applies to measurable properties, not assumptions made in thought experiments. It is noted that while an object can appear stationary, measuring its exact position and momentum simultaneously would violate the uncertainty principle. The wave function's role in representing probabilities rather than certainties is emphasized, and it is concluded that while an object can be measured as stationary, this does not imply absolute rest in quantum mechanics. Ultimately, the conversation highlights the nuanced relationship between measurement, uncertainty, and the nature of quantum particles.
chrisphd
Does the uncertainty principle contradict the idea that an object can be at rest relative to an observer? For example, in physics class we examined an electron in a box, and we assumed the walls of the box are stationary relative to the observer. But the uncertainty principle says delta p times delta x > hbar/2. So the walls of the box would have a definite position and momentum relative to the observer, violating the principle. Where is my error in logic.
The atoms in the walls of the box behave according to quantum mechanics.
They will have uncertain positions, too.
However, I would expect thermal energy to introduce more error into this experiment than uncertainty.
Your missing the point here. I know that the particles in the box exhibit uncertainty. But for the thought experiment, it was assumed that the walls of the box where stationary. However, i am asking, doesn't assuming another object is stationary to an observer contradict the uncertainty principle, as we are assuming we are able to know the exact position and momentum of that object.
If you assume something to be true, then it is true.
The uncertainty principle is a restriction on what can be measured, not what can be assumed.
Not so. Certain things can be assumed to be true in a thought experiment, but if such assumptions contradict the laws of nature then the thought experiment achieves nothing. It is like assuming speed of light is greater than c to deduce a fact. The fact will be irrelevant to physics, as in physics the speed of light is c. The uncertainty principle is more generally that one cannot know exact position and momentum rather than one cannot measure exact position and momentum. This is because in order to know something about an observable, you need to measure it.
Basically, for the conclusion to be correct, the premises of the argument must also be correct. I am wondering if the assumption is an incorrect premise.
When you calculate the energy eigenstates and the corresponding eigenvalues (i.e. the energy levels) of a "particle in a box" you're just solving the Schrödinger equation for a potential with a certain shape (zero in a certain interval and infinity everywhere else). The uncertainty principle says something about the shape of the wave function, not about the shape of the potential, so there's no disagreement there.
My question in simplest terms is, can an object be at rest relative to an observer and not violate the uncertainty principle?
I don't see why not. It can have these properties, but good luck measuring both at once.
Well, one reason why not is because relative to the observer, he would observe a momentum of 0, and therefore he would know the exact momentum of the object. Uncertainty principle is error in position times error in momentum is greater than hbar/2. However if he knows exact momentum, the left hand side of the equation will be 0 violating the law
If you had asked "Can an object be measured at rest relative to an observer and not violate the uncertainty principle?" so the answer is still yes.
Now, if you asked, "Would an electron ever be measured at rest relative to an observer?" then the answer is no. You'd get an electron cloud if you measured an electron that's part of an atom. If you confined an electron with a very focused laser beam, you could get it to stay within a very tiny area. With good enough equipment, you could still notice it move when it's position is measured optically.
That is good news. But i still don't see how it is possible looking at the mathematics.
Holy mother of..., you've never seen anything stay still before??
All sorts of objects stay still relative to an observer when measured.
I'm looking around my apartment, and most of the objects I see appear still.
Sure, there is large error in my measuring tool (bad eyesight).
The uncertainty in the position of my bookshelf is well under the threshold of detection.
LOL. One could argue that the things are you are looking at only appear to be stationary. They are still moving at very low speeds, but you have failed to measure their speed to high enough degree of accuracy. However, I'm not saying that its not possible to measure the speed of an object to be 0 relative to an observer. I'm just wondering how it doesn't violate the uncertainty principle.
I'm sorry for not explaining myself well.
The bottom line is, as Fredrik said, we're not talking about a material box.
We're talking about a wave function.
I think that's what was initially misleading.
Say we capture an electron with an electric field.
We measure the position of the electron a bunch of times.
The probability to find the electron at any location is the square of the wave function.
The wave function has a maximum, and that maximum may be stationary.
This is not to say that the electron is stationary.
Hope this is helpful.
Ok. But the question still remains, is it possible to measure something to be stationary and not violate the uncertainty principle?
That question is not unique.
If the object is small enough so that uncertainty is significant, then uncertainty effects the results of experiment.
If the object is large, then you can measure it to within the accuracy of your instruments.
You could measure an electron in the same exact place twice, but it would be a coincidence. The next time it may be somewhere else, because the photon you used to measure it last time sent it off on on a new trajectory.
Furthermore, the more accurate you want your measurements to be, the shorter wavelength of light you need to use. Shorter wavelength means higher energy, means higher momentum delivered to the poor electron being so cruelly observed.
It isn't possible to measure something to be stationary, period. This would make the wave function zero everywhere (and turn the uncertainty principle into \infty\cdot 0\geq\frac\hbar 2)
Why would the wavefuntion be 0?
Fredrik said:
It isn't possible to measure something to be stationary, period...
What about my bookshelf? It's stationary, in a classical sense.
I think what chrisphd is struggling with is that our classical concept of stationary is as unreal in quantum mechanics as absolute space is in general relativity.
Actually the wave function would be zero everywhere but one point, where it would be 1.
You don't see particles behave like this in nature, though.
So the wavefunction is more like a kronika delta (however you spell it) function, which would actually be a point rather than a wave?
The wave function is a mathematical function which, when squared, produces the probability distribution for finding a particle over all space.
Integrating the probability distribution from negative infinity to infinity must result in one, meaning the probability of finding the particle somewhere in all of space is one.
Therefore, if the particle is "still", it is described by a wave function that has the value one at some point, and zero elsewhere.
Like I said, this does not describe any particles of nature.
The wave function (at a fixed time) can be written as
\psi(x)=K\int_{-\infty}^\infty g(p)e^{-ipx/\hbar}dp=
where K is a normalization factor. (This is the most general solution of the time-independent Shrödinger equation). To measure the momentum to be between a and b is to change the state so that g is 0 everywhere except in the interval (a,b). To measure the momentum to be exactly 0 is to change g so that it's 0 everywhere except at 0. So the integral is definitely 0 unless g is infinite at 0. g will actually be infinite at 0 in this limit, but it's not enough. g becomes a Dirac delta function, so
\psi(x)=K\int_{-\infty}^\infty\delta(p)e^{-ipx/\hbar}dp=K
Now try to normalize this:
1=\int_{-\infty}^\infty|\psi(x)|^2dx=K^2\int_{-\infty}^\infty dx=K^2\cdot\infty \implies K=0[/itex]
The wave function would be 0 everywhere, but its Fourier transform (i.e. the momentum-space wave function) would be 0 everywhere except at one point where it would be infinite).
Yeah, I know. We've all been there.
In quantum mechanics, the answer to the question "where is the particle now?" isn't a number (or 3 numbers), it's a complex-valued function. That takes a while to get used to.
Is that so?
A detector can measure the position of a particle as a number, right?
Q: Where is a particle going to be? A: Function.
Q: Where is that particle I measured? A: Number.
So...
Q: Is it possible to measure something to be stationary and not violate the uncertainty principle?
A: Sure. Detector reads position X at time t1 and t2. It's possible. Not likely with an accurate detector and a small particle like an electron.
A measurement is never exact. If the precision of the measurement is dx, then you have only measured the position to be in the interval (x-dx,x+dx). The result of the measurement is a number, x. The position of the particle is (still) represented by a wave function. The only thing that has changed is that the new wave function is zero everywhere outside that interval.
Fair enough.
I concede that there is no meaning to absolute position or absolute rest in quantum mechanics.
I maintain that in my electron experiment, I have a working definition of measured position and measured rest.
Ok, but theoretically, what is the limit to how small we can make dx?
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 16 ·
