Understand Limits: Why Does ∞1=lim n→∞ (n+1/n-1)?
  • Context: Undergrad
  • Thread starter Thread starter Jarvis88
    Limits
The discussion revolves around understanding the limit of the expression ##\lim_{n \rightarrow \infty} \left( \frac{n+1}{n-1} \right)^{n}## and its classification as an indeterminate form of type ##1^\infty##. Participants explore different methods to evaluate this limit and clarify misconceptions regarding the limit of ##\frac{n+1}{n-1}## itself.
  • One participant expresses confusion about why the limit of ##\frac{n+1}{n-1}## is considered to be of the indeterminate form ##1^\infty##.
  • Another participant suggests that the standard way to evaluate the limit is to rewrite it as ##1 + \frac{2}{n-1}##, which leads to a clearer understanding that the limit approaches 1.
  • Multiple participants clarify that the limit in question is actually ##\left(\frac{n+1}{n-1}\right)^{n}##, which is indeed an indeterminate form of type ##1^\infty##.
  • One participant provides a detailed breakdown of the limit evaluation process, indicating that the naive approach leads to confusion.
  • Another participant asserts that the limit of ##\frac{n+1}{n-1}## itself is simply 1, countering the initial claim of it being indeterminate.
There is no consensus on the initial confusion regarding the classification of the limit as ##1^\infty##. While some participants clarify that the limit is indeed 1, others maintain that the expression in question is the indeterminate form. The discussion remains unresolved regarding the interpretation of the limits involved.
Participants express uncertainty about the application of L'Hopital's rule and the handling of indeterminate forms. There are also indications of missing context regarding the original teaching or explanation that led to the confusion.
Jarvis88
I'm trying to understand why the ## \lim_{n \rightarrow \infty}
( \displaystyle \frac {n+1}{n-1} )
## equals the indeterminate form 1?
I ask because we have started going over sequences and it was used as an example. I understand how to go from here- taking the ln of both sides and using L'Hopital's rule to get the limit of e2.
Could you write down what you teacher said in full. I have no idea what is going on.
The standard way to evaluate the limit is just observe ##\frac{n+1}{n-1} = \frac{n-1+2}{n-1} = 1 + \frac2{n-1}## and then it becomes obvious.
Edit: alternative ##\frac{n+1}{n-1} = \frac{1+n^{-1}}{1-n^{-1}}## and then apply limit laws. Again the limit is 1.
We were discussing using L'Hopital's rule for indeterminate forms to evaluate the sequence below. I just don't understand how that limit is
1. I guess I'm still fuzzy on how to figure out limits?
Oh, the limit you want to evalute is ##\left(\frac{n+1}{n-1}\right)^{n}## and not ##\frac{n+1}{n-1}##. Yes that's ##1^\infty## indeterminate form.
This is what happens when students do it naively:
##\lim_{n\to\infty}\left(\frac{n+1}{n-1}\right)^{n} = \left(\lim_{n\to\infty}\frac{n+1}{n-1}\right)^{\lim_{n\to\infty} n} = \left(1+\lim_{n\to\infty}\frac2{n-1}\right)^{\lim_{n\to\infty} n} = 1^\infty##.
Thank you so much for the explanation!
It doesn't. The limit here, which apparently isn't the one you really meant to ask about, is 1.
##\lim_{n \to \infty}\frac{n + 1}{n - 1} = \lim_{n \to \infty}\frac n n \frac{1 + 1/n}{1 - 1/n} = 1##
For any finite value of n, n/n is 1, and as n gets larger, the other fraction approaches 1 in value, making the limit equal to 1.
  • · Replies 16 ·
