Understand Newton's law of universal gravitation
The discussion focuses on calculating the gravitational force acting on the Earth due to the Sun using Newton's law of universal gravitation. The formula used is F = G(mE)(mS)/r^2, where G is the gravitational constant (6.67*10^-11 N(m/kg)^2), mE is the mass of the Earth (5.98*10^24 kg), mS is the mass of the Sun (1.99*10^30 kg), and r is the distance between them (1.5*10^11 m). A calculation error was identified, leading to the correct gravitational force being approximately 9.81 m/s² when using the composite constant (GmE/r^2) for an object near the Earth's surface.
  • Understanding of Newton's law of universal gravitation
  • Familiarity with gravitational constant (G)
  • Basic knowledge of mass and distance measurements in physics
  • Ability to perform scientific calculations with exponents
  • Study the derivation of Newton's law of universal gravitation
  • Learn how to calculate gravitational force between two masses
  • Explore the implications of gravitational force in orbital mechanics
  • Investigate the significance of the gravitational constant in various contexts
Students studying physics, educators teaching gravitational concepts, and anyone interested in understanding the forces acting in celestial mechanics.
aligass2004
http://i241.photobucket.com/albums/ff4/alg5045/1012540B.jpg
Consider the Earth following its nearly circular orbit (dashed curve) about the sun. The Earth has mass 5.98 *10^24 kg and the sun has mass 1.99 *10^30 kg. They are separated, center to center, by r=93 million miles=150 million km. What is the size of the gravitational force acting on the Earth due to the sun?
F = G(mE)(mS)/r^2
Pretty much I just plugged and chugged to try to get the answer, which of course of was incorrect.
F = (6.67*10^-11)(5.98*10^24)(1.99*10^30)/ (1.5*10^11)^2 = 3.53*10^66
Hi aligass2004,
F = G(mE)(mS)/r^2
I think you have a calculator error here. If you multiply these numbers together, you don't get an exponent of 66.
aligass2004 said:
That was the problem. Thank you!
http://i241.photobucket.com/albums/ff4/alg5045/1012540D.jpg
Now it asks for the value of the composite constant (GmE/r^2), to be multiplied by the mass of the object mO in the following equation?
http://i241.photobucket.com/albums/ff4/alg5045/render.gif
What is the statement of the problem?
I'm assuming re is not the radius of the earth, or you could just calculate that quantity from what you already have. Are the forces cancelling on that object, or is something else happening?
r is the radius of the earth. I still just don't understand what it's asking for.
If you can, please post the entire problem (all parts, even those that you may not have gotten too yet) exactly as its written, and maybe I or someone else can help you interpret it.
If all you need is the gravitational constant G times the mass of the Earth divided by the radius of the Earth squared, you can find those quantitites easily (they are usually inside the covers of the first-year physics textbooks).
"Now it asks for the value of the composite constant (GmE/r^2), to be multiplied by the mass of the object mO in the following equation?"
The solution to the composite constant is simply 9.8 m/s^2.
Convert the radius of 6.38*10^3 km to meters... which is 6,380,000 m
(GmE/r^2)= (6.67*10^-11)(5.98*10^24)/(6,380,000)^2
Calculate this and you will get 9.81 m/s^2
  • · Replies 23 ·
