Understanding Angular Velocity Calculations for Rotating Objects
The discussion focuses on the calculations of angular velocity for rotating objects, specifically using the formula v = w x r. The user initially questioned the rearrangement of the formula to w = v/r and clarified that angular velocity (w) must be measured from the center of rotation. The correct application of the formula involves understanding the relationship between linear velocity at different points on a roller, leading to the conclusion that v = 2rω when measuring from the bottom to the top of the roller. The importance of the instantaneous center of rotation (IC) in these calculations is emphasized.
  • Understanding of angular velocity and linear velocity concepts
  • Familiarity with the formula v = w x r
  • Knowledge of the instantaneous center of rotation (IC)
  • Basic trigonometry and the concept of similar triangles
  • Study the application of the instantaneous center of rotation in various mechanical systems
  • Learn about the relationship between linear and angular motion in physics
  • Explore advanced topics in rotational dynamics, including torque and moment of inertia
  • Investigate the use of angular velocity in real-world applications, such as roller coasters and gears
Students studying physics, particularly those focusing on mechanics, as well as educators and professionals involved in engineering and design of rotating systems.
Nikstykal
v = w x r
I got the answer correct after a few tries, but I am little confused on why it has to solved this specific way. I know that v = w x r, so why can I not just say w = v/r? Is it because w is measured from the center of the roller so v = w x r would be vcenter, not vtop?
That is how I ended up solving it, but I wanted to make sure I didn't get there "accidentally" or misinterpreted the process.
Using that diagram and concept of similar triangles:
tan θtop = tan θcenter
Stop/2r = Scenter/r
Stop = 2*Scenter, Scenter = rθ
Stop = 2rθ
d(Stop)/dt = vtop = d(2rθ)/dt = 2rθ' = 2rωtop
thus, ω = v/2r
Any reasoning as to why I have to do this would be much appreciated!
That's for the centro of the motion is at the bottom of the roller. Your formula should be applied as ##v=2r\cdot\omega,## where ##2r## is the distance from the bottom to the top.
Ahh, i forgot, when using v = w x r you have to always measure from from IC unless using relative velocity equation. Thank you!
