Understanding \DeltaH and \DeltaE in Constant Volume Process
  • Context: Graduate
  • Thread starter Thread starter phymatter
    Law Thermo
8 replies · 3K views
phymatter
What is the difference between [tex]\Delta[/tex]H and [tex]\Delta[/tex]E in a constant volume process ?
By definition it is always true that
[tex] H=E+pV[/tex]
At constant volume you have
[tex] \Delta_V H=\Delta E+V\Delta p[/tex]
Here you see the difference in the term.
What exactly did you want to know?
but acc to first law Heat supplied = internal energy + work done
i.e.
i.e. [tex]\Delta[/tex]h = [tex]\Delta[/tex]U + [tex]\Delta[/tex]W
and [tex]\Delta[/tex]W = [tex]\Delta[/tex](pv) and
[tex]\Delta[/tex](pv) = P[tex]\Delta[/tex]V + V[tex]\Delta[/tex]P and
for work done V[tex]\Delta[/tex]p is taken as zero so how come can we say here V[tex]\Delta[/tex]P is not taken as zero here?
Hi jeedoubts, welcome to PF. Can you give a reference for these two equations? I doubt very much that they're correct. For example, work is defined as [itex]P\Delta V[/itex], not [itex]\Delta(PV)[/itex].
I agree with Gerenuk's answer.
what does the quantity v[tex]\Delta[/tex]p refers to then?
physically what does it represent??
Neither equation is correct in general. The correct equations are
[tex] \mathrm{d}W=p\mathrm{d}V[/tex]
(or with the other sign if you consider the work done on the system) and if you wish
[tex] \mathrm{d}(pV)=p\mathrm{d}V+V\mathrm{d}p[/tex]
It follows that only for constant volume or constant pressure processes the work can be described by
[tex] W=p\Delta V\qquad\text{(const. p or const. V)}[/tex]
Is it very important to know what is the general equation and what the special case. These special cases only apply if the conditions are met.
Mapes is correct.
