Understanding Faraday's Law: The Role of Magnetic Flux and Imaginary Surfaces
The discussion revolves around the understanding of magnetic flux in the context of Faraday's law of electromagnetic induction. Participants explore the role of an imaginary surface associated with a loop of wire in a magnetic field, the implications of changing magnetic flux, and the relationship between field lines and induced current. The conversation includes theoretical aspects and practical implications of these concepts.
  • Some participants express confusion about the necessity of an imaginary surface for calculating magnetic flux, questioning its relevance when the area inside the loop is perceived as empty space.
  • Others argue that the space within the loop is not empty, as it contains an electric field with a non-zero curl, which is relevant to Faraday's law.
  • A participant references the microscopic and macroscopic forms of Faraday's law, emphasizing that the equations apply to any surface with the same boundary as the loop.
  • There is a discussion about the distinction between a wire moving through a magnetic field and a loop, with some asserting that a loop is necessary for current to flow.
  • Participants debate whether the focus should be on the field lines inside the loop or those that the wire "sees" when cutting through the magnetic field.
  • One participant mentions that the common explanation of "cutting field lines" is a simplification that only holds true under certain conditions, specifically when the magnetic field is unchanging.
Participants do not reach a consensus on the role of the imaginary surface or the interpretation of magnetic flux in relation to induced current. Multiple competing views remain regarding the significance of field lines inside the loop versus those encountered by a moving wire.
Some limitations in the discussion include assumptions about the nature of the electric field in the loop, the dependence on the definitions of magnetic flux, and the conditions under which certain explanations apply. The discussion does not resolve these complexities.
Freddy86
Hi, please could someone help explain how magnetic flux works in Faraday's law as I struggle with electromagnetism.
From what I understand, if you have a loop of wire in a magnetic field then you get an induced current if the flux is both changing and perpendicular to the plane of the loop. What I don't understand is why they fix an imaginary surface to the loop. The area inside the loop is just empty space so how has that got anything to do with the induction process? The wire just needs to 'see' a changing magnetic flux so the area inside the loop seems to serve no role as far as I can see, what am I missing? Also, what area do you assign for the flux when the magnetic field is outside the loop? Thank you in advance for any help offered!
no, it's not empty space, it contains an electric field with a non-zero curl
faraday's law (one of Maxwell's laws) has a microscopic form
curlE = -∂B/∂t​
and a macroscopic form
C E.dl = - ∂/∂t ∫S B.dA
the first equation applies in what you call the empty space
the second equation applies (via stokes' theorem) to any surface S with the same boundary C (ie not just to the flat planar surface) :wink:
but there's no flux :confused:
The contrary is the case! The local law is generally valid, i.e.,
[tex]\vec{\nabla} \times \vec{E}=-\partial_t \vec{B}[/tex]
(in SI units).
Using Stokes's Law in integrating this equation over an arbitrary surface then yields
[tex]\int_{\partial F} \mathrm{d} \vec{x} \cdot \vec{E}=-\int_F \mathrm{d}^2 \vec{F} \cdot \partial_t \vec{B}.[/tex]
This is, of course still generally valid.
tiny-tim's formula, where the time derivative is taken out of the surface integrals, however, holds if and only if the surface is time-independent. A generally valid formula takes into account a possible time dependence of the surface. Let [itex]\vec{v}(t,\vec{x})[/itex] the velocity of the point [itex]\vec{x}[/itex] on the surface at time [itex]t[/itex]. Then the general formula reads
[tex]\int_{\partial F} \mathrm{d} \vec{x} \cdot (\vec{E}+\vec{v} \times \vec{E})=-\frac{\mathrm{d}}{\mathrm{d}t} \int_{F} \mathrm{d}^2 \vec{F} \cdot \vec{B}.[/tex]
There is a lot of confusion in the understanding of Faraday's Law, because this mathematical identities are often not clearly stated. For more details, see the very good article in Wikipedia:
http://en.wikipedia.org/wiki/Electromagnetic_induction
curlE = -∂B/∂t​
Thank you for your answer. When you do that experiment where you move a wire through a magnetic field and 'cut' the flux lines then you are only concerned with the wire cutting the magnetic field lines. However, it seems that when one is dealing with a loop of wire and a changing magnetic field inside the loop, it seems to be concerned with field lines inside the loop where there is no flux cutting of a wire taking place since there is no wire there. Would you not only be concerned with the field lines that are 'seen' by the wire as appose to those inside the space within the loop?
Freddy86 said:
… where you move a wire through a magnetic field and 'cut' the flux lines then you are only concerned with the wire cutting the magnetic field lines.
you mean a wire with two ends, ie not a loop?
but then there's no current … you need a loop (a circuit) for current to flow
in terms of current, you can check the potential difference between the ends of the wire by connecting them to a voltmeter outside the magnetic field
that makes a loop whose intersection with the magnetic field is getting larger and larger …
it is the fields lines cutting that loop which we count, not the field lines cut by the wire
for current, it is always the field lines that are 'seen' by the loop :wink:
Thank you tiny-tim that makes a lot more sense. In terms of flux cutting in a loop, how do you explain the experiment where you swipe a wire in between two bar magnets to generate a current? Most websites seems to imply that it is the number of field lines the wire cuts through but as you pointed out it should be the number of field lines cutting the loop shouldn't it?
Yes … "the number of field lines the wire cuts through" is a short-cut that only works (to find the current) if the magnetic field lines are unchanging. :smile:
  • · Replies 27 ·
  • · Replies 25 ·
