Understanding Fourier Transforms: Solving Confusion with Even Functions
4 replies · 3K views · last reply
engcon
Hi, I got a problem in which I have to find the Fourier Transform of a function f(t) defined:
f(t) = { 1 - |t|, |t| < 1
0, |t| > 1 }
Well , I found the Fourier transform by working out the integral f(t)e^(-iwt) with the limits being -inf to +inf (and I got the right answer).
Now, since f(t) is an even function, does that mean I can use the Fourier cosine transform?
I tried to work it out and got a different answer, and basically I'm confused? :frown:
Any help is appreciated, thanks!
Yes, the function is even, and so you can use the Fourier cosine transform. However, since you've not posted your solution, I can't see why you're getting a different answer.
eng_pro said:
yeah i have the same problem here!
Your user-name is very similar to the OP's. Coincidence?
yes i did it
i used: Fcosine = 2*int (1-t) cos (wt) dt from 0 to1
yep it is coincidence..i don't know the OP's username k
