Understanding Implications of 10MΩ Resistor in Circuit
  • Thread starter Thread starter antoine1
    Parallel
The discussion revolves around the implications of a 10MΩ resistor in a circuit involving potentiometers and an Arduino Mega2560. Participants explore the effects of the resistor on total resistance, current flow, and the functionality of the circuit, including voltage readings and potential short-circuit risks.
  • Some participants suggest that the 10MΩ resistor does not significantly influence the total resistance of the circuit.
  • There is a belief that adding a branch could increase current due to its effect on voltage multiplication, though this is not universally accepted.
  • One participant notes that the resistor may not assist the potentiometers when their resistance decreases.
  • Another participant mentions the importance of having resistance in series with each pot to prevent short circuits when pots are set to zero.
  • Concerns are raised about the schematic's clarity, specifically whether the variable resistors are potentiometers or rheostats, which affects the interpretation of the circuit.
  • Some participants express confusion over the schematic's design, suggesting it may be poorly drafted and could lead to misinterpretation of the circuit's functionality.
  • There is a discussion about the conventions used in circuit diagrams, particularly regarding the representation of potentiometers in different regions.
Participants do not reach a consensus on the implications of the 10MΩ resistor or the clarity of the schematic. Multiple competing views and uncertainties remain regarding the circuit's design and functionality.
Participants highlight ambiguities in the schematic, including the representation of variable resistors and the potential for misinterpretation. There are unresolved questions about the circuit's behavior under different conditions.
antoine1
Hello,
Could someone please help a noob like me understand the implications of having the 10MΩ resistor in the circuit i have uploaded. So far I've gathered it doesn't really influence the total resistance.
I thought it could decrease the current but adding a branch should slightly increase it since it add to the number multiplying the voltage in the formula..
And it doesn't help the pots handling the current when they go down in resistance, does it?
Thanks a lot,
antoine
antoine1 said:
Hello,
Thanks a lot,
antoine
Welcome to the PF.
What is that circuit from? It would appear to do nothing, except maybe to set voltages between 5V and ground on the "Analog Input" signals...?
Hi berkeman,
The voltage across the pots is read by the analogue inputs of an Arduino Mega2560 (using the Atmel Atmega2560) programmed to send MIDI messages.
Thanks
antoine
antoine1 said:
Hi berkeman,
Thanks
antoine
Ah, then yes, the 10M resistor does nothing.
As a side note, there should be some resistance either in series with each pot individually, or a resistor between one of the power rails and the rest of the pots.
This would keep the power rails from seeing a short if all Pots are turned to 0.
That's not the way I interpret the diagram. It looks like the rails will always see the parallel combination of the full pot resistances, and the wipers just select up and down between the rails. The wipers are varying their output voltages, not varying any resistances, I believe.
that schematic raises more questions than it answers.
first question is are those variable resistors potentiometers or rheostats?
the arrow through element infers rheostats, which are just variable resistors
but both ends of element are shown connected as in a potentiometer where wiper taps voltage partway through element
and a rheostat is usually drawn with one end unconnected.
i suspect the arrow should be perpendicular to element and end where arrowhead touches element, as in a potentiometer
else the circuit makes no sense. Setting one variable resistor to zero would make all seven AN's read zero.
I call that sloppy draftsmanship.
if indeed they are potentiometers,,,
i notice they're located at various wheels and knobs.
Perhaps there's a connector and wiring harness involved?
then the 10meg could provide a minimum load for 5V line provided it remains in circuit when that connector is unplugged.
the picture is incomplete. my diagnosis is lazy drafting.
EDIT oops i see Berkeman got there already.
Berkeman, you are correct (no surprise there) - I see it drawn that way as well. I guess I shouldn't post early in the morning :-/
Yes, although I think jim hardy brings up good points about the ambiguities in the schematic as drawn.
Since it's an Arduino schematic, which is an Italian company (if memory serves me), perhaps that's just the European convention for a pot.
Just like, for resistors, they use a box and we use a squiggly.
  • · Replies 44 ·
  • · Replies 17 ·
