Undergrad How do I convert mass units in physics?
  • Thread starter Thread starter isai
    Mass Units
The discussion focuses on converting mass units in physics, specifically from kilograms (kg) to kilogram-force seconds squared per meter (kgf.s²/m). The confusion arises from the distinction between mass and weight, particularly in the context of US customary units versus the metric system. Participants emphasize the importance of understanding the relationship between force, mass, and acceleration, encapsulated in the equation F=ma. It is recommended that beginners avoid this topic until they have a solid grasp of fundamental physics concepts.
  • Understanding of Newton's Second Law (F=ma)
  • Familiarity with SI units and their conversions
  • Knowledge of gravitational acceleration (g=9.8 m/s²)
  • Basic concepts of mass and weight differentiation
  • Research the differences between mass and weight in physics
  • Learn about unit conversions in the metric system
  • Study the implications of using kilogram-force in engineering applications
  • Explore practical examples of force and mass calculations in physics problems
This discussion is beneficial for physics students, educators, and engineers who need to understand mass unit conversions and the relationship between mass and force in practical applications.
isai
I am enrolled in a course related with physics, and we have a table of equivalencies of units to get the right units of frequencies.
Code:
    Stiffness   Mass        Frequency
    tonf/m      ton.s^2/m   rad/s
    kN/m        ton         rad/s
    N/m         kg          rad/s
    kgf/m       kgf.s^2/m   rad/s
I have always work with the third row, but I want to understand the conversion between mass units only; for example to convert mass from kg to kgf.s2/m. What I have to do it?
I have always a problem for this: if I have 50kgf, so to get the mass value for this force, I have to divide by gravity, and I have kgf-s2/m. Furthermore, if I want to convert first to Newtons, then, I have to multiply by 9.80N, and finally divide by gravity to get the mass, and the value of mass is 50kg, different from the other calculation. What have I done wrong?
Please help me.
This seems to be the mass multiplied by the gravitational acceleration g. You don't need that.
The US units have this weird mass/weight confusion where "pound" can be both, the metric system does not.
Likes gmax137
Many engineers use "kilogram-force" analogous to the US concept of "pounds-force" -- simply because of the convenience when designing bridges which cross rivers on the surface of the Earth (where g=9.8 m/sec^2). In my opinion this isn't a good idea, I think it is mostly older engineers who were schooled in the "customary units" and switched to SI later.
If (when) you get confused, write down F=ma and see that mass has units F/a.
@mfb is right, this can be very confusing and hard to keep straight in your mind. If you are new to physics it would be better to leave this alone for now, and look at it again later after you have done a lot of problems, then it will make more sense.
  • · Replies 19 ·
