- 10,490
- 1,639
Rather than argue about Newtonian theory, let's try a different aproach.
Consider the GR case, as outlined in http://math.ucr.edu/home/baez/einstein/
more specifically
http://math.ucr.edu/home/baez/einstein/node3.html
So, the second derivative of the rate of change of the volume of a sphere of coffee grounds is proportional to the volume of the coffee grounds multiplied by the density of matter - plus, a pressure term.
Note that, as Baez & Bunn explain, this depends only on the amount of matter contained within the ball. External gravity via external matter does not cause the volume to shrink. If we put the coffee grounds near the Earth, there will be the tension and compression terms you noted. The result will be that the ball will grow longer in one direction, shorter in the other two, and the second derivative of the volume will be zero.
Now, skip on a bit to:
http://math.ucr.edu/home/baez/einstein/node7.html
They apply the above result to a sphere of coffee grounds, placed at rest relative to each other.
The result is that the ball shrinks, due to gravity, and that the acceleration required is just the volume of the ball * (rho+3P).
Thus, with no cosmological constant, we see that the expansion deaccelerates due to gravity.
If we insist that our ball hold its shape, by making it rigid, and put strain gauges on it, we will see that the ball is in compression. Gravity tries to make the ball shrink, and the forces that make the ball a rigid body oppose gravity.
I thought that this was easy to explain from a Newtonian viewpoint, but we got tied up in a lot of difficulties. So perhaps the GR argument as presented by Baez & Bunn will actually make the explanation simpler.
I do agree that the force is independent of direction. I'm replacing the ball by a very-lightweight and open "rigid bar". And the goal is to find the tension (or compression) in the bar. The endpoints of the bar will correspond with two of the particles in Baez's ball of coffee ground. The fact that the ball of coffee grounds shrinks means that the bar would also shrink, unless a force opposes it.
Thus the B&B argument shows that a bar, in free space, would experience compressive forces. This is not due to the expansion of space, but is due to the matter contained within space, so that one has to be careful that the bar experiment doesn't change the density of the local matter distribution.
more specifically
In any event, we may summarize Einstein's equation as follows:
[tex]{\ddot V\over V} \Bigr\vert _{t = 0} = -{1\over 2} (\rho + P_x + P_y + P_z).[/tex]
This equation says that positive energy density and positive pressure curve spacetime in a way that makes a freely falling ball of point particles tend to shrink. Since E = mc^2 and we are working in units where c = 1, ordinary mass density counts as a form of energy density. Thus a massive object will make a swarm of freely falling particles at rest around it start to shrink. In short: gravity attracts.
Given a small ball of freely falling test particles initially at rest with respect to each other, the rate at which it begins to shrink is proportional to its volume times: the energy density at the center of the ball, plus the pressure in the x direction at that point, plus the pressure in the y direction, plus the pressure in the z direction.
