Understanding Parametric equations
18 replies · 4K views · last reply
Dethrone
I have a few trivial questions regarding finding equations of the tangent line:
1) Find an equation of the tangent line to the parametric curve:
x = 2 sin 2t y= 2 sin t
at the point $$(\sqrt{3}, 1)$$
The textbook says that point "corresponds to the parameter value $$ t= \frac{pi}{6}$$"
How do they know that? After testing for a few minutes, I noticed that tan-1$$(\sqrt{3}/1) $$ = $$ t= \frac{pi}{6}$$ Is that how they determined it?
2) Similar question but
x = t sin t
y = t cos t
point (0, -pi)
Using $$\frac{dy}{dx}$$ = $$\frac{\frac{dy}{dt}}{\frac{dx}{dt}}$$, I got
$$\frac{(cos t -sint)}{(sin t + cos t)}$$ = slope of tangent lineI then plugged the "0" from the point (0, -pi) into the equation...
(cos 0 - sin 0) / (sin 0 + cos 0) = 1
Is that right/am I on the right track?
What I would do for the first one is use the chain rule as follows:
$$\frac{dy}{dx}=\frac{dy}{dt}\frac{dt}{dx}$$
Now, using the given parametric equations, we find:
$$\frac{dy}{dx}=\frac{2\cos(t)}{4\cos(2t)}= \frac{\cos(t)}{2\cos(2t)}$$
To determine the value of $t$, we could use:
$$y(t)=2\sin(t)=1\,\therefore\,\sin(t)=\frac{1}{2}$$
$$x(t)=2\sin(2t)=\sqrt{3}\,\therefore\,\sin(2t)= \frac{\sqrt{3}}{2}\,\therefore\, \cos(t)=\frac{\sqrt{3}}{2}$$
With no given restriction on $t$, we could state that these conditions correspond to:
$$t=\frac{\pi}{6}+2k\pi=\frac{\pi}{6}(12k+1)$$ where $$k\in\mathbb{Z}$$
However, the value of $k$ will not affect the equation of the tangent line, so we may as well let $k=0$, and use:
$$t=\frac{\pi}{6}$$
So, now you may compute the slope of the tangent line, and then using the given point, apply these to the point-slope formula to get the equation of the tangent line.
What do you find?
x = t sin t
y = t cos t
point (0, -pi)
You are using an incorrect value for $t$...does $y(0)=-\pi$?
$$\frac{dy}{dx}=\frac{4\cos(2t)}{2\cos(t)}= \frac{2\cos(2t)}{\cos(t)}$$
$$t=\frac{\pi}{6}$$
What do you find?
Is it not
Since,
$$\frac{dy}{dt} = 2 cost $$
(dy/dt [2 sin t] = 2 cos t)
$$\frac{dx}{dt} = 4\cos(2t) $$
(dy/dt [2 sin 2t] = 2 cos(2t) * 2)
Rido12 said:
Is it not
$$\frac{dy}{dx}=\frac{2\cos(t)}{4\cos(2t)}= \frac{\cos(t)}{2\cos(2t)}$$...
Yes, I misread, and have fixed my post.
No, I guess I will try to use the same logic as 1)
x(t) = t sin t
y(t) = t cos t
We want the point (0, -pi)
Hence,
x(t) = t sin t = 0
therefore, t = 0
y(t) = t cos t = -pi
?Question 1)
Got stuck here:
How does sin 2t = cos t?
There are other values of $t$ which make $\sin(t)=0$. As you go around the unit circle, what is the next one?
That would be at pi or 180 degrees.
Correct! :D
And what is $y(\pi)$?
Rido12 said:
Question 1)
Got stuck here:
$$\sin(2t)=2\sin(t)\cos(t)=\frac{\sqrt{3}}{2}$$
Now, from the other equation, we know $$2\sin(t)=1$$, so we may write:
$$\cos(t)=\frac{\sqrt{3}}{2}$$
MarkFL said:
Correct! :D
$y(\pi)$ = pi cos pi = -1 pi
- - - Updated - - -
Very neat, you used the first equation to aid with the second. Is it always like this, (that we use the first equation to aid with the second)?
$$t=\frac{\pi}{6}$$
What do you find?
Back to question number 1!
Now that we determine t = pi/6, we can plug it back into the slope of the tangent line
$$\frac{\cos(t)}{2\cos(2t)} = \frac{\cos(pi/6)}{2\cos(pi /3 )} $$
Now that simplifies to root 3 / 2
Final Step:
Y2 - y1 = m (X2 - X1)
y2 - 1 = root 3 / 2 * (x2 - root 3)
y = (root 3 / 2) x - (1/2)
Finishing this question:
Plug this into the slope of the tangent line:
(cos pi - sin pi) / (sin pi + cos pi) = -1 / -1 = 1?
- - - Updated - - -
You need to find the value of $t$ that satisfies both equations with regards to the given point. For example, using the first equation:
$$t\sin(t)=0$$
We know then by the zero-factor property that:
$$t=k\pi$$ where $$k\in\mathbb{Z}$$
Now, using this value for $t$ in the second equation, we find:
$$k\pi\cos(k\pi)=-\pi$$
$$k\cos(k\pi)=-1$$
We now see that $$k=1$$ is the only viable value of $k$.
As far as always being able to use one equation to aid in solving the other, I can't say this is the case, but we can use whatever we find in one to help with the other when possible because they are in essence simultaneous equations.
I get it now! I guess we can use whatever tactic we want, as long as it satisfies both equations.$$t=k\pi$$ where $$k\in\mathbb{Z}$$
What does Z refer to?
Where can I read more about the zero factor thing?
Also, I've edited the first post of this page with the correct answer :)
Final Step:
Yes, that looks correct.
I would refrain from mixing uppercase and lower case variables. I would state:
We have the slope: $$m=\frac{\sqrt{3}}{2}$$
and the point: $$(\sqrt{3},1)$$
hence application of the point-slope formula gives us the tangent line:
$$y-1=\frac{\sqrt{3}}{2}\left(x-\sqrt{3} \right)=\frac{\sqrt{3}}{2}x-\frac{3}{2}$$
Arranging this in slope-intercept form, we have:
$$y=\frac{\sqrt{3}}{2}x-\frac{1}{2}$$
$$k\in\mathbb{Z}$$ just means that $k$ is an arbitrary integer.
The zero-factor property just means that if your have:
$$ab=0$$
then you know the equation is true when either $a=0$ or $b=0$, you are probably familiar with it when solving a quadratic by factoring, where you equate each factor in turn to zero to find the roots.
Answer to question 1.Plug this into the slope of the tangent line:(cos pi - sin pi) / (sin pi + cos pi) = -1 / -1 = 1
putting it in point-slope formula gives us y = x - pi
y2 - y1 = m (x2 - x1
y + pi = m (x)
y = x - pi
Answer in the back of the textbook : y = (1/pi) x - pi
Did I make a mistake somewhere?
Yes, check your differentiation again, recalling you need to apply the product rule.
Whoops, did it right on paper, but when I tried to type it on here, I mistakened "sint (t)" to be sin (t). Thanks a lot! You were of great help!
