- #1
zenterix
- 488
- 71
- Homework Statement
- I'd like to understand the concepts of mutual and self inductance.
- Relevant Equations
- Suppose we have the following setup
That is, a solenoid with ##N## turns, length ##l##, radius ##R##, and a current ##I## flowing.
Let's approximate the solenoid as an infinite solenoid (ie, ##l## is very large).
Then, the magnetic field inside the solenoid is
$$\vec{B}=\mu_0 nI\hat{k}=\frac{\mu_0NI}{l}\hat{k}\tag{1}$$
Suppose ##\frac{dI}{dt}> 0##. Then, in the solenoid the magnetic field is changing and so is the magnetic flux.
This variance of the magnetic field creates a phenomenon called electromagnetic induction.
Faraday conjectured that this phenomenon is due to a non-electrostatic electric field ##\vec{E}## which satisfies
$$\mathcal{E}=\oint_C\vec{E}\cdot d\vec{s}=-\frac{d\Phi_B}{dt}=\frac{d}{dt}\iint\vec{B}\cdot d\vec{A}\tag{2}$$
where ##\mathcal{E}## is called the electromotive force. This isn't an actual force. It has units of voltage. It is like a potential difference but isn't one either since this new electric field isn't conservative.
As I understand it, in the case of the solenoid, we have ##N## turns, not loops.
On the other hand, we can approximate the solenoid as being composed of ##N## loops.
The flux through the solenoid is then just the sum of the flux through the ##N## loops.
$$\Phi=N\iint_{\text{turn}}\vec{B}\cdot d\vec{A}=n^2l\mu_0n\pi R^2I$$
(I am not sure about the term "flux through the solenoid" above. Flux is defined relative to a surface, so this term doesn't seem correct).
There is a linear relationship between ##\Phi## and ##I##. The proportionality constant is the self-inductance ##L=n^2l\mu_0n\pi R^2##.
Why is this important?
It seems to be because we have the concept of self-induced emf ##\mathcal{E}_L##.
$$\mathcal{E}_L=-N\frac{d\Phi_B}{dt}\tag{3}$$
$$=-N\frac{d}{dt}\iint_{\text{turn}}\vec{B}\cdot d\vec{A}\tag{4}$$
$$=-N\frac{d}{dt}\left (\frac{\mu_0 NI}{l}\pi R^2\right)\tag{5}$$
$$=-\frac{N^2\mu_0\pi R^2}{l}\frac{dI}{dt}\tag{6}$$
$$=-n\mu_0l\pi R^2\frac{dI}{dt}\tag{7}$$
If this back emf were not present, the magnetic field would simply increase due to the presence of ##I## in (1).
At this point, as I understand it, we add the whole new field ##\vec{E}## that we mentioned previously. It doesn't come from previous theory, but rather from experiments.
This is the part I'd like to understand more deeply.
I have a few questions but let me tackle them in parts.
The negative sign in equations (3)-(7) are there because of Lenz's law, which seems to also be simply a law obtained from experimental evidence.
$$\mathcal{E}_L=-L\frac{dI}{dt}=-n^2l\mu_0 \pi R^2 \frac{dI}{dt}=\oint_C \vec{E}\cdot d\vec{s}\tag{8}$$
The rightmost integral has units of voltage of course, which is energy per charge.
But what is ##C## in the case of our solenoid?
