Understanding solutions of Dirac equation
5 replies · 2K views · last reply
Markus Kahn
Full disclaimer: This post is the same as the one in the following link with some slight modifications (I'm the author of the original) https://physics.stackexchange.com/questions/469386/understanding-solutions-of-the-dirac-equation
In one of the lectures that I'm currently taking we encountered the Dirac equation. The general solution was given as
$$\psi ( x ) = \sum _ { s } \int \frac { d ^ { 3 } \bf { p } } { ( 2 \pi ) ^ { 2 } 2 \omega _ { p } } \left[ a _ { s } ( p ) u ^ { s } ( p ) e ^ { - i p \cdot x } + b _ { s } ^ { * } ( p ) v ^ { s } ( p ) e ^ { + i p \cdot x } \right],$$
where
$$u^{s}(p)=\begin{pmatrix}{\sqrt{\sigma \cdot p} \xi^{s}} \\ {\sqrt{\overline{\sigma} \cdot p} \xi^{s}}\end{pmatrix} \quad\text{and}\quad v ^ { s } ( p ) = \begin{pmatrix} { \sqrt { \sigma \cdot p } \xi ^ { s } } \\ { - \sqrt { \bar { \sigma } \cdot p } \xi ^ { s } } \end{pmatrix}.$$
Note that we defined ##\sigma^\mu \equiv (1,\vec{\sigma})## and ##\bar\sigma^\mu \equiv (1,-\vec\sigma)## and ##s\in\{+,-\}## for
$$\xi^+ \equiv \begin{pmatrix}1\\0\end{pmatrix},~\xi^-\equiv\begin{pmatrix}0\\1\end{pmatrix}.$$
My problem is now that I'm a bit confused on how to evalute the expression ##\sqrt{p\cdot\sigma}\xi^s##. If I understood correctly we have ##p\cdot \sigma = p_\mu\sigma^\mu## which makes this expression a matrix. But how am I supposed to take the square-root now?
This expression can also be found in Perskin chapter 3, S. 46.
All given above.
some notes:
There was actually no proof given why ##u^s(p)## or ##v^s(p)## should solve the Dirac equation, only a statement that one could prove it using the identity
$$(\sigma\cdot p)(\bar\sigma\cdot p)=p^2=m^2.$$
We were using the Wely-representation of the ##\gamma##-matrices, if this should be relevant. I think I can prove the statement if someone could explain to me how one should evaluate the expression ##\sqrt{p_\mu\sigma^\mu}\,\xi^s##. In Perskin QFT book I found the explanation
"where it is understood that in taking the square root of a matrix, we take the positive root of each eigenvalue."[pp. 46]
but honestly I can't figure out how this is supposed to work for ##p_1\neq p_2\neq 0##.
I'd like to stress here that I'm not interested in alternative ways of expressing solutions, I'd like to understand why we can write them in this specific form..
Markus Kahn said:
some notes:
Well, you can verify that when you square the quantity:
##A + B \overrightarrow{\sigma} \cdot \overrightarrow{p}##
you get ##A^2 + 2 A B \overrightarrow{\sigma} \cdot \overrightarrow{p} + B^2 p^2##
So if you choose ##A## and ##B## appropriately, you can get this to equal ##E + \overrightarrow{\sigma} \cdot \overrightarrow{p}##.
So we can write: ##\sqrt{E + \overrightarrow{\sigma} \cdot \overrightarrow{p}}## as
##\sqrt{\frac{E+m}{2}} + \sqrt{\frac{1}{2(E+m)}} \overrightarrow{\sigma} \cdot \overrightarrow{p}##
(there are other solutions with minus signs in various places). I'm not sure how this relates to the hint about eigenvalues, though.
Thank you for the reply! I could reproduce all of your calculations, so now the only question is what the connection to the eigenvalues is as suggested by Perskin.
You can sort-of connect it with eigenvalues in this way:
You have a 2x2 matrix ##A## and you want to take its square-root. You can try to write ##A## in the form:
##A = U D U^{-1}##
where ##D## is a diagonal matrix whose entries are the eigenvalues of ##A##. In that case, we can write
##\sqrt{A} = U \sqrt{D} U^{-1}##
where ##\sqrt{D}## just means replacing each diagonal entry of ##D## by its square-root. We can verify that
##\sqrt{A} \sqrt{A} = U \sqrt{D} U^{-1} U \sqrt{D} U^{-1} = U \sqrt{D} \sqrt{D} U^{-1} = U \sqrt{D} U^{-1} = A##
So if we knew the matrix ##U## to use, then we could use the eigenvalues to take the square-root.
Does this work if we some of the eigenvalues are negative? I always thought that this was only possible if ##A## is positive definite...
Well, if the eigenvalues are negative, then the square-root will necessarily have imaginary eigenvalues. For example, a square-roots of the matrix ##\left( \begin{array} \\ -1 & 0 \\ 0 & -1 \end{array} \right)## are:
##\left( \begin{array} \\ i & 0 \\ 0 & i \end{array} \right)##
(there is more than one square-root of a matrix)
