Understanding the Cosine Rule: Deriving the Other Two Formulas
The discussion centers around the derivation and understanding of the cosine rule in triangles, specifically how to derive the three formulas associated with it and their applicability to different types of triangles. Participants explore the interchangeability of triangle side labels and the implications for using the cosine rule in various contexts.
  • One participant expresses confusion about deriving the other two formulas from the cosine rule, noting that they understand the derivation for one specific case.
  • Another participant corrects the initial formulas presented, suggesting the use of conventional labeling for sides and angles in triangles.
  • Some participants discuss the reasoning behind providing all three formulas, indicating that beginners may struggle with changing labels when solving problems.
  • A participant introduces a vector approach to demonstrate the cosine rule, suggesting a geometric interpretation involving vectors in a two-dimensional space.
  • There is acknowledgment from participants about the relationship between the cosine rule and the Pythagorean theorem under specific angle conditions.
  • One participant reflects on their understanding of the cosine rule and its application to non-standard triangles, indicating a need for further exploration of the concept.
Participants generally agree on the validity of the cosine rule and its derivations, but there is no consensus on the necessity of all three formulas or the best approach to understanding them. Some participants express uncertainty about applying the cosine rule to various triangle configurations.
Some limitations include the potential for confusion regarding the labeling of triangle sides and angles, as well as the need for clarity when applying the cosine rule to non-standard triangles. The discussion also highlights the dependence on geometric interpretations and the use of vectors.
This discussion may be useful for students studying geometry, particularly those grappling with the cosine rule and its applications in various triangle types, as well as those interested in vector mathematics.
Taylor_1989
So here is my question, I understand how to derive the cosine rule from, both triangles acute and obtuse. My problem is the 3 formula you get from this equation.
When I derive from a triangle I get the formula: c^2=a^2+b^2-2abcos∅
so how do you derive the other two formula, I read that the letter are interchangeable so you can place them where every you like on the triangle. If that is the case, why do we show the other two formula? I presume people reading this post know of the other two formula I am referring to if not here they are: a^2=c^2+b^2-2cbcos∅
b^2=a^2+c^2-2accos∅.
This has been on my mind for a while, I would appreciate if someone could clarify my confusion. Big thanks in advance.
Mathematics news on Phys.org
First, your formulas are not quite correct because you have the same angle, ∅, in each.
Instead use the usual convention that we label sides of the triangle by small letters and the opposite angle by the corresponding capital letter:
a^2= b^2+ c^2- 2ab cos(A)
b^2= a^2+ c^2- 2ac cos(B)
c^2= a^2+ b^2- 2ab cos(C)
Yes, you are correct that it does not matter how we label the sides so we don't really need all three. But all three are often given because some beginners have difficulty "changing" letters when they need to calculate several parts of the same triangle. That is, in a given problem, we are given that "c" is a specific side and many people just don't like the idea that we can then think of "c" representing a different side. Of course, the three equations are all gotten from the first by interchanging the letters.
Thanks for the reply back. I realized after I posted what I had done wrong but did not have any time to correct.
Once again thanks for clearing that up for me.
Suppose we had ##u,v\in\mathbb{R}^2## such that ##u=B-A## and ##v=C-A##, then ##u-v=B-C##. Then ##a=||u-v||##, ##b=||v||##, and ##c=||u||##. So $$||u-v||^2=||u||^2+||v||^2-2uv\cos A,$$ or $$(u-v)\cdot(u-v)=u\cdot u+v\cdot v-2u\cdot v.$$ This is true and can easily be checked..
Thanks for the reply, can sort of see how that is true, I have only just started studying vectors, so I bit slow on the uptake of that proof. I have see something similar, if memory serves; on wki. I am studying vectors today so will hopefully try to understand your method a little better by the end. I am under the assumption these are a vector notation? As I said just getting into mechanics and the use of vectors in pure math.
By the way, notice that if \theta= 90 degrees (or \pi/2 radians) the cosine is 0 giving the Pythagorean theorem: c^2= a^2+ b^2
If \theta= 0 degrees (or radians) cosine is 1: c^2= a^2+ b^2- 2ab= a^2- 2ab+ b^2= (a- b)^2. That is, rather than a triangle we have a single line segment. The angle has "closed" down so that the "third side" is just the distance from A to B.
If \theta= 180 degrees (or \pi radians) cosine is -1: c^2= a^2+ b^2+ 2ab= a^2+ 2ab+ b^2= (a+ b)^2. Now, the angle has "opened" up so that we have a single line segment including both a and b.
Okay now I am with ya, see where you are coming from. It also makes the above proof easier to see. Thanks for that. Big help.
Okay so first I appolgse for reopening this thread, but I think I may have made an erro of judgment. See I assumed I actually knew what the cosine rule was all about, because I read the book and went yep that proof works. My problem cam up when I was looking at a question on a strange looking triangle, I knew that I would apply the cosine rule, which is easy enough; any Tom dick nd Harry can do that ( English expression I believe ). So what bugged me was when I tried to apply the proof, couldn't because, I only knew the proof for 2 specific triangles, which are normally the ones given, so I found and article on cut the knot which I believe explain it quite well. Now my gist of what I see is that, to prove for any trangle to find the length of the opposite side, you have to create a right hand triangle with the triangle given, then just follow normal protocol as you would to say prove a obtuse triangle.
I have posted the article for someone to have a quick look to see if I have got the general idea right?
http://www.cut-the-knot.org/pythagoras/cosine.shtml
  • · Replies 19 ·
