Understanding the graphical effect of f(x+a)
  • Thread starter Thread starter Aion96
    Shift
The discussion centers on the transformation of the function f(x) when replaced with f(x+a), specifically addressing the intuition behind the leftward shift of the graph. While adding a to x seems to suggest a rightward movement, it is clarified that the graph of f(x+a) actually shifts left by a units for a > 0. Participants emphasize the importance of distinguishing between the movement of the graph and the coordinate system, noting that a positive shift in the function's argument corresponds to a leftward shift in the graph. Various explanations and examples are provided to reinforce this concept, including the use of simple linear functions and parabolic equations. Ultimately, the conversation highlights the need to reconcile intuitive understanding with mathematical conventions regarding function transformations.
Aion96
I'm trying to understand the transformation of a function when replacing x with x+a.
None
Solution attempt. I know that f(x+a) shifts the function f(x) by a units to the left for a>1, however, I find this counterintuitive because adding a to x feels like it should move the graph to the right rather than to the left. I understand the algebra, but I struggle with the intuition behind it.
Given a function f(x), we know that a point on its graph is (x,f(x)). Now, if we consider f(x+a), I want to determine the new corresponding points. My reasoning is:
  1. The point (x+a,f(x+a) lies on the graph of the original function f(x).
  2. The goal is to find the point (x,f(x+a)), and we notice that its obtained by moving the point (x+a,f(x+a) a units the left.
  3. To express the transformation using x instead of x+a, we rewrite the point as (x,f(x+a)).
This suggests that the graph of f(x+a) is obtained by shifting the graph of f(x) a units to the left. I believe my reasoning is correct, but I want to confirm:
  • Is my step-by-step logic sound?
  • Could someone provide an intuitive explanation or a different approach to understanding this shift?
Likes hutchphd and OmCheeto
Yes, you are right. The problem you are struggling with, and I often, too, is to distinguish between the movement of the object (the function graph) and the movement of the coordinate system, here the ##x##-axis. Moving the function to the left is the same as shifting the coordinate system to the right. Other than doing it on a table, we do not have an exterior coordinate system (the table) here to distinguish between both.
Likes Aion96 and OmCheeto
Aion96 said:
Homework Statement: I'm trying to understand the transformation of a function when replacing x with x+a.
Relevant Equations: None
Good question. Adding ##a## moves the value ##x+a## to the right, but not ##x## itself. The graph is based on ##x##, which can start farther to the left. Then its value is shifted to the right before evaluating ##f(x+a)##.
That would be for a > 0, not a > 1.
A more correct restatement of what you wrote is this: the graph of y = f(x + a), with a > 0, is shifted to the left by a units, relative to the graph of y = f(x).
Likes neilparker62, Aion96 and FactChecker
You mean for ##a \ge 0##. There's nothing wrong with, for example, ##f(x + \frac 13)## which shifts the graph ##\frac 13## of a unit left. [Edit: aha, @Mark44 beat me to it!]
One thing I (a non-mathematician) found helpful when first meeting this - a rather long time ago -was to consider ##y = x## and ##y=x+1##. Sketching the two graphs immediately shows that replacing ##x## by ##x+1## shifts the first graph 1 unit left.
By considering the point where each of these graphs crosses the x-axis, it isn't too difficult see why this happens,
Of course ##y=x-1## produces a right shift by 1 unit.
I found it useful to memorise the directions of the shifts for ##f(x \pm a)##. This saves time in exams and reduces the risk of a mistake.
(FWIW, the first time I found this really useful was understanding the basic wave equation ##y(x,t) = A\sin(kx - \omega t)##. The shape is a simple sine curve ##y = A\sin(kx)## and this shape steadily moves right as the ##\omega t## term steadily increases, giving a moving sine curve. Apologies for sneaking some physics into a maths thread!)
If a = 0, there is no shift at all. That's why I didn't include 0.
The equation might have to do with wave equations in physics, but the underlying concepts are from mathematics.
The equation can be rewritten as ##y(x,t) = A\sin(k(x - \frac \omega k t))##. This represents two transformations: a compression of the graph toward the y axis by a factor of k (if k > 1), followed by a translation to the left by ##\frac \omega k## (if that fraction is positive). If 0 < k < 1, there is an expansion away from the y axis. Note that these transformations must be performed in the order I showed, or the resulting graph won't be correct.
Likes neilparker62
If you interpret a shift to the left by a negative amount to be a shift to the right by a positive amount, you don't need to worry about the sign of ##a##. :-)
Yes. I thought about that at the time. On reflection (no pun intended) I wish I had used ##a \gt 0##. I hadn't seen your post at the time.
Of course! I only pointed out the wave equation example because it brought back happy memories of something I realised/discovered for myself. And, in the post, I did explicitly apologise for sneaking-in some physics!
When you shift the graph ## G_1=\{(x,f(x))|x\in X\} ## to the left by ## a ## units you will get the graph ## G_2=\{(x-a,f(x))|x\in X\} ##. The graph ## G_2=\{(x-a,f(x))|x\in X\} ## is exactly the same as the graph ## \{(x,f(x+a))|(x+a)\in X\} ##.
The sets are identical, but the graphs are not. As sets, ##x## is a dummy variable that disappears. As a graph of ##x## versus ##f(x)##, ##x=0## sets the origin, and the origins of those two are not the same.
  • Skeptical
Likes vela and SammyS
Not a rigorous post . But how i interpret ##g(x)=f(x+a)## is just setting the argument of ##f## to zero ,i.e, ##x+a=0## this means : ##x=-a## . So , whatever graph you have for ##f(x)## , you get the same value of ##f(0)## at ##x=-a##,i.e, ##g(-a)=f(-a+a)=f(0)## (##a>0##) . So , it is as good as shifting the graph of ##f## left by ##a## units . Similarly , you can try other values of ##f## to get a 'feel' . But i have just made a trick like this so that i don't waste time .
Let's say : ##f(x)=x## , then ##g(x)=f(x+3)=x+3## , So, ##g(0-3)=f(0)##
Your ##f(0)## value is shifted by ##3## units to the left for ##g## , so are all the other values . Hence , you can say ##g(x)## is the graph of ##f(x)## shifted by ##3## units to the left
Likes FactChecker
Some will say it's arbitrary but I think the correct formula for a horizontal shift is ##f(x-a)## and not ##f(x+a)## in the first place. The former lines up with the op's intuition (mine too!) which is that a positive value of a will shift the graph to the right. I have old text books which write (for example) the equation of parabolas as ##f(x) = a(x-p)^2+q## whereas our syllabus document uses ##f(x)=a(x+p)^2+q ##.
It all depends on whether we constrain a to be a positive real number.
In your parabola example, if p > 0 and q > 0, the graph of ##f(x) = a(x + p)^2 + q## will be translations to the left by p and up by p q of the graph of ##y = ax^2##
In your parabola example, if p > 0 and q > 0, the graph of ##f(x) = a(x + p)^2 + q## will be translations to the left by p and up by p of the graph of ##y = ax^2##
Yes - it's intended that a is a real number but not necessarily positive. For example f(x-(-2)) would represent a left shift of 2 units on the graph of f(x).
In the parabola example, the problem with p>0 creating a left shift is that it is counter-intuitive as per the op's original observation. A positive value of p should result in a right shift since that is the positive direction on the horizontal x-axis. So I'd go with the old text books:
Edit: Replaced image from text book with one which includes a useful explanation.
Before people learn better, their intuition can be wrong... A purpose of education is to correct erroneous intuitions.
Likes FactChecker
There is no police force that will enforce an official "Horizontal Graph Shifting Rule". If a student is initially confused about right/left shift for a positive/negative ##a##, he should be able to figure it out and accept the result. There are more difficult concepts ahead.
Likes neilparker62
If we go by the horizontal shifting rule which I have imaged above, the op's intuition is completely correct. A positive value of h leads to a right shift and a negative value of h leads to a left shift. On the other hand if we prefer a convention that writes the shifting rule as F(x) = f(x + h), then an exact "counter-intuition" applies whereby positive values of h lead to left shifts and and negative values of h lead to right shifts.
Similarly a student could be puzzled because his/her reasonable intuition indicates that electrons flow from negative to positive whereas there is an established convention that current flows from positive to negative. There is - however - nothing particularly wrong with the student's intuition in this instance.
Agreed that intuition can be wrong - as is evidenced by Aristotle's erroneous belief that heavier objects fall faster than light ones. Corrected by Galileo.
left by p and up by q
Right, and that's what I meant. Fixed in the original
I'm not sure this is a comparable example. The labels "positive" and "negative" came about in the first place, I believe, because of a faulty understanding in how electrons flowed in a circuit.
  • · Replies 21 ·
  • · Replies 23 ·
