Understanding the Parametric Equation for a Sphere
The discussion revolves around understanding the parametric equations for a sphere and the reasoning behind the ranges of the parameters used in these equations. The original poster attempts to clarify the differences between the equations for a circle and a sphere, particularly focusing on the parameter ranges for u and v.
  • Participants explore the reasoning behind the range of v being from 0 to pi, questioning why it does not extend to 2 pi as it does for u. Some suggest that allowing v to range from 0 to 2 pi would trace the sphere twice. Others discuss the implications of parameter ranges in programming contexts and how they relate to the geometric representation of a sphere.
The discussion is ongoing, with participants providing insights and clarifications regarding the parameter ranges. Some have offered supportive responses to the original poster's inquiries, while others are still exploring the implications of the ranges in different contexts, such as programming.
There is mention of specific programming constraints and the potential for misunderstanding in the application of the parametric equations. The original poster expresses confusion about the parameter ranges provided by their teacher, indicating a need for further clarification on the definitions used in the context of VRML.
DorumonSg
The equation for a circle is
x = r cos(u)
y = r sin(u)
Where u is 0 <= u <= 2 pi, because 2 pi is for calculating circle.
While a sphere is
x = r cos(u)cos(v)
y = r sin(v)cos(v)
z = r sin(v)
Where u is the same, 2 pi but v is 0<= v <= 1 pi.
Why only 1 pi for v? and not 2? Why does it not have to turn a full circle?
Think about the cross-section of the sphere into the yz-plane. This is a circle and running u from 0 to 2 pi rotates the circle through the entire sphere. Therefore we should only let v range over a semi-circle if we don't want to trace the sphere out twice. So v ranges from 0 to pi.
Similarly, you can compute the volume of a sphere and see explicitly that integrating v from 0 to 2 pi will give you twice the volume of the sphere.
Putting it in the layman terms does it mean :
x = r cos(u)
y = r sin(u)
0 <= u <= 2 pi
This is to draw the circle, a ratio of a circle is 2 pi.
x = r cos(u)cos(v)
y = r sin(u)cos(v)
z = r sin(v)
0 <= u <= 2 pi
0 <= v <= pi
The extra stuff is to make the circle "pop up" till it becomes a Sphere.
As its already a circle which is already round, it only needs to "pop up" itself on a straight line(180 degree) to become a Sphere?
If you increase the degree, there will be no visible change(Maybe the some part become thicker in color due to more drawing.) because its all within the 360 degree of the circle?
Is that right?
Yes that's a very good way to think about it.
I used the formula for a Sphere and I got only half a Sphere :
x=cos(u)*cos(v);
y=sin(u)*cos(v);
z=sin(v);
Basically u = 0.0001 to 6.282 and v = 0.0001 to 3.141, its a piece of programming code but the logic is the same.
Erm..., did I do anything wrong?
x=cos(u)*cos(v);
y=sin(u)*cos(v);
z=sin(v);
The volume element is
r^2 \sin u ~dr~du~dv
and the integral should give 4\pi R^3/3. I'm not sure what you did.
Erm... not that, I am trying to define a Sphere using VRML a 3D programming language. My teacher gave us this, its derive from the equation of a Sphere :
parameters [0.0001 6.282 0.0001 3.141]
definition "
x=cos(u)*cos(v);
y=cos(u)*sin(v);
z=sin(u);"
Parameter actually just means u's range is from 0.0001 to 6.282 or 0 <= u <= 2 pi and v is 0.0001 to 3.141 or 0 <= v <= pi
This generates a sphere...
But I find it weird that he is using the range of u as 0 <= u <= 2 pi and v as 0 <= v <= pi.I tried switching the range for u and v and got half a sphere instead...
Shouldn't u be 0 <= u <= pi and v be 0 <= v <= 2 pi according to the definition of a Sphere :
x = r cos(a)cos(b)
y = r sin(a)cos(b)
z = r sin(b)
Where 0 <= a <= 2 pi and 0 <= b <= pi?
definition "
x=cos(u)*cos(v);
y=cos(u)*sin(v);
z=sin(u);"
x = r cos(a)cos(b)
y = r sin(a)cos(b)
z = r sin(b)
Oh, sorry I didn't notice that before. Yes, you're right. If you look at his choice of coordinates and try to compute the volume, you'll actually find zero. So those ranges are not properly spanning the sphere.
Thanks a lot.
I think I got it already.
I haven't been looking at the range at an angle point of view.
I think I got it already, thanks a lot.
  • · Replies 20 ·
