Understanding Velocity in Standing Waves | Wave Motion Homework"
The discussion revolves around understanding the properties of standing waves, particularly focusing on their velocity and the mathematical representation of such waves. The original poster is analyzing a standing wave formed by the superposition of two wave functions and is confused about the physical meaning of velocity in this context. Additionally, there is a second problem involving the general solution of the wave equation for a string, where participants are exploring the separation of variables method and the nature of the functions involved.
  • Mixed
  • Participants discuss the implications of standing waves having no velocity in the x-direction and question what this means physically. There is uncertainty about whether the velocity should be considered zero or related to the wave number.
  • In the second problem, there is exploration of Fourier analysis and separation of variables as methods to find expressions for the wave functions. Some participants express confusion about the necessity of infinite sums in the representation of the wave functions.
The discussion is ongoing, with participants sharing insights about separation of variables and the wave equation. Some guidance has been offered regarding the structure of the solutions, but there is still a lack of clarity on certain aspects, particularly concerning the infinite sum representation and the physical interpretation of velocity in standing waves.
Participants note that they have not yet covered Fourier analysis in their studies, which may be impacting their understanding of the problems. There is also mention of the need to factor terms in the wave equation to find appropriate solutions.
joe:)
1)I'm analysing a standing wave formed by superposition of Asin(kx-wt) and Asin(kx+wt) so it becomes 2Asinkxcoswt
It asks me to comment on the velocity of this wave. But I thought it was a standing wave - so it has no velocty in the x direction..
So what is its velocity - what does it mean physically - is it just 0? Or w/k? thanks
2) I'm given that general solution of wave equation of string length L can be written as the sum from r=0 to r=infinity of Arsin(xrpi/L)sin(r pi c t /L) + Brsin(xrpi/L)cos(r pi c t /L)
Then I'm told that stationary waves y=f(x)g(t) exist on a string length L.
I'm told f(x) = Asin(kx) I'm told to find an expression for k and find an expression for g(t)
I'm not really sure how to solve 2) to be honest..
I thought the f(x) would have to be an infinite sum and k = r pi / L where r is any integer..
I'm a bit confused..any help? Thanks
Problem 2 delves into a little Fourier analysis, so if you're familiar with that at all try thinking in that direction.
As for the expression, you can use separation of variable to arrive at forms for the solution.
The wave will be described by the infinite sum of f(x)g(t) so the f(x) is actually only a component.
Edit:
I've absent mindedly forgot to mention that you should look at the wave equation as well, should help you a bit.
Thanks..
We haven't done Fourier yet..
I'm not sure how to find the expression by separation of variables..could you explain please? How will f(x) just be a constant A times sinkx? surely its an infitite sum? Confused :S
Also any ideas on Q1?
Q1 I'm not really sure.
Fourier is actually pretty easy but I bet this one can be done without.
Separation of variables is a method of solving partial differential equations. The idea is that you have PDE that describes what you're looking at (in this case you're interested in the wave equation). You assume a solution f(x,t) = g(x)h(t) and plug that into your PDE. Then you separate terms so that you only have one variable of each type on one side, so all the x's on one side and all the t's on the other. You can then set each side of the PDE to a separation constant (this is your k) and solve the ordinary differential equation.Though to be honest, the above is probably far more than you're actually being asked. I think that if you look at the equation for number 2 a bit longer you'll see that you can actually just match terms and pull out a g(t). Just look at what you can factor out and remember that sums are valid solutions.
sorry..i really can't see it at the moment...? I swear the expression for f(x) should be an infinite sum too?
thanks for your patience
It's not. You have the right k.
Try factoring f(x) out the given equation. Remember the solution is f(x) times g(x).
  • · Replies 21 ·
