Optimal Shape for a Submersible Object with 360 Degree Maneuverability
The ideal shape for a submersible object with 360-degree maneuverability depends on its size, purpose, and propulsion method. Large objects like submarines benefit from streamlined shapes for efficient movement during high-speed maneuvers, while smaller objects, such as underwater cameras, can utilize directional thrusters with less emphasis on shape. A spherical pressure hull is necessary for deep dives, but it should be surrounded by a hydrodynamic lenticular outer hull to reduce drag. This design allows for efficient traversal in any direction without rotation, and for vertical movement, a tilting zigzag or spiral approach is recommended. Overall, the combination of hull shapes and thruster systems plays a crucial role in optimizing maneuverability underwater.
RICKYtan
For a given submersible object that has 360 directional maneuverability, what would be an ideal shape for that object?
Sphere?
**360 degree directional maneuverability meaning jets strategically placed around the object for propulsion, without rotating the object
Much depends on what the purpose of the object is , it's size and how it is powered .
For a large sized object like a submarine which moves at relatively high speeds it is almost always easier to change position using steered turns under forward motion - just like for a car . Normal streamline shapes are best for this . Auxiliary thrusters are sometimes used but only for position control at lower speeds .
For smaller objects like underwater cameras which move relatively slowly the use of directional thrusters is more practical . In this case the shape of the object is not that important and is usually decided by simple practical considerations . Several different thruster systems are used . Most common is a single thruster which can be swung round to different angles relative to the hull . Thruster is usually either a propeller and drive which can be swung round complete or a fixed propeller and drive with moveable guide vanes .
Does the vessel have a pressure hull? If it will dive deep it will need a spherical pressure hull.
A sphere does not travel well, so surround the pressure hull with a hydrodynamic lenticular outer hull, (water flooded), so it looks more like a flying saucer with only the top and bottom of the sphere showing outside the lens. That has less horizontal drag and can traverse efficiently in any direction without needing to rotate.
To rise or fall, avoid vertical movement. It would be more efficient to tilt and traverse in a zigzag, or travel in a wide spiral.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 17 ·
