Unequal force at uneven attachment heights?
  • Thread starter Thread starter derek88
    Force
The discussion revolves around the physics of a cable suspended between two poles at different heights, focusing on the tension forces created by wind. One participant argues that the vertical tension at the taller pole is greater than at the shorter pole, leading to the conclusion that the z-direction tension should also reflect this difference. However, the opposing view suggests that the z-tension forces at both poles are equal. The conversation includes considerations of angles and the effects of wind on the cable's behavior, with a proposed experiment to test the theories. Ultimately, the participants agree that practical experimentation or detailed mathematical analysis is necessary to resolve the debate.
derek88
Unequal force at uneven attachment heights??
Friends:
My boss and I have been debating this physics problem:
Imagine that you have a cable suspended in between two poles (Pole 1 and Pole 2). The attachment height at Pole 1 is greater than that at Pole 2. As for the orientation of the x, y, and z-axis, let's say that the poles are set on the x-axis and they're pointing up in the direction as the y-axis. We both agree that the vertical tension (due to the cable) at Pole 1 is greater than the vertical tension at Pole 2, i.e. Vtension1 > Vtension2.
A wind blows on the cable. We will say that the wind blows along the z-axis. The cable swings outwards along the z-axis. This creates forces at the cable's pole attachments, in the z-direction (we can call the forces Ztension1 and Ztension2). I believe that since Vtension1 > Vtension2, it must be true that Ztension1 > Ztension2. My boss believes that Ztension1 = Ztension2. Which one of us is right?
I appreciate any thoughts on this problem! :):):)
This one is easy to set up in an experiment - rig two poles with a length of heavy string and a Newtonmeter at each end. This should be definitive, where any analysis can always be argued over.
You can also analyse a simplified picture by imagining now that the cable is a few masses joined by massless "string" and see how it plays out for different numbers of masses.
Formally:
http://www.aejm.ca/V4N1/Chatterjee.V4N1.pdf
... you'd have to modify this for crosswinds.
I'm thinking that if you sketch out the profile down the x axis, then the angle the cable makes to the tall pole will be less than the angle it makes to the short pole, which kinda suggests that the z-component of the tension against the tall pole is less than the short one.
Since the long side presents a larger surface area to the wind, it may get blown out more.
But I think the rule-of-thumb weight is leaning towards less z-tension for the tall pole. But it tells you what to watch for in the experiment.
Probably someone has a computer program for computing this.
Thanks for the reply!
I just assumed that the "blowout angle" (the angle from vertical) that the cable makes in a windy environment would be the same throughout the entire length. This is because I imagined that the cable was like a series of pendulums (just imagine an invisible string connecting each point of the cable to the axis of rotation). The angle of swing of a pendulum is Theta = arctan(Windforce/Cableweight). If we assume that both the wind force and the cable weight is evenly distributed, it seems that the blowout angle would be the same everywhere. Any thoughts?
Draw the picture you just proposed and you'll see you have to move one of the poles so it still connects with it's end of the cable.
But like I said - you can argue endlessly about this kind of thing. Either do the real math (see link) or do the experiment.
Well, I'll try to do the experiment by placing a stick on the ground and another on an elevated position, string a cable in between them, then turn on a big fan. I'll see if one stick falls down first or not. I'll post my results.
Sight along the two sticks and estimate the angles to each.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
