"Unexpected error in file" in MCNP
13 replies · 5K views · last reply
khary23
Hello,
I am getting the following error
I have gone through the code and noting seems to be amiss. Does anyone have any ideas?
khary23 said:
Hello,
What code ? All I see is a text file with no code in it.
Thats weird. I'll try again and if there is still no code then that might explain the error.
Here's what I see. I'm not aware of any computer language in which any of this would anything other than data.
Is this code in "MCNP" ?
Dose to water Ir-192 source
C Cell Cards
11 1 -22.42 -1 IMP:p,e=1 $ cylinder that defines source volume
12 3 -8.02 -3 2 5 IMP:p,e=1 $ volume that defines outer radius of casing
13 3 -8.02 -7 -2 1 IMP:p,e=1 $ volume that defines inner radious of casing
14 5 -0.99355 -4 -20 10 19 IMP:p,e=1 $ 2 19
16 3 -8.02 -2 -8 7 6 IMP:p,e=1 $ volume that defins end cap
17 4 -4.01 -10 -4 IMP:p,e=1 $ drive cable -4.81
C 20 2 -0.00125 -18 3 IMP:p,e=1
C 21 2 -0.00125 18 10 -19 IMP:p,e=1
C 22 2 -0.00125 -4 19 IMP:p,e=1
22 5 -0.99355 -20 3 10 -19 IMP:p,e=1 $ #11 #12 #13 #14 #16
23 5 -0.99355 20 -21 IMP:p,e=1 $ Tally Cell
24 5 -0.99355 21 -4 IMP:p,e=1
300 0 4 IMP:p,e=0 $ creates grave yard
C Surface Cards
1 RCC 0 0 -0.175 0 0 0.35 0.03 $ cylinder surface that defines source
2 RCC 0 0 -0.246 0 0 0.492 0.035 $ inner radius of casing
3 RCC 0 0 -0.246 0 0 0.492 0.045 $ outer radius of casing
4 SO 40 $ Graveyard
5 PZ -0.246 $ Bottom of source casing
6 RCC 0 0 0.35 0 0 0.072 0.03 $ end cap cylinder
7 PZ 0.175 $ plane that defines the top of the source
8 PZ 0.246 $ top of source casing
9 PZ -0.175 $ plane that defines the bottom of the source
10 RCC 0 0 -0.246 0 0 -40 0.043 $ drive cable
C 11 SO 10
19 SO 30
20 SO 0.9
21 SO 1.1
C 22 SO 325
C Data Cards
MODE p e $photon and electron transport
C tally card
*F4:p 23
# DE4 DF4 $ convert MeV/cm^2 to MeV/g
0.0010 4065
0.0015 1372
0.0020 615.2
0.0030 191.7
0.0040 81.91
0.0050 41.88
0.0060 24.05
0.0080 9.915
0.0100 4.944
0.0150 1.374
0.0200 0.5503
0.0300 0.1557
0.0400 0.06947
0.0500 0.04223
0.0600 0.03190
0.0800 0.02597
0.1000 0.02546
0.1500 0.02764
0.2000 0.02967
0.3000 0.03192
0.4000 0.03279
0.5000 0.03299
0.6000 0.03284
0.8000 0.03206
1.0000 0.03103
1.2500 0.02965
1.5000 0.02833
C Source is a cylindrical Isotropic Ir-192 photon emitting source centered at origin.
SDEF CEL 11 VEC 0 0 1 POS 0 0 -0.174 RAD D1 EXT D2 ERG D3 PAR 2
C Energy Spectrum of Ir-192 (MeV)
C Radius of circle centered on the axis of the cylinder
SI1 0.029
C Distance from the POS to the end of the cylinder
SI2 0.348
SI3 0 0.110093 0.13634348 0.17698 0.2013112 0.20579549
0.28004 0.2832668 0.29595827 0.30845692 0.31650791
0.329312 0.3744852 0.4164714 0.420532 0.46807152
0.4845780 0.48530 0.489039 0.5885845 0.59337
0.59935 0.60441464 0.61246564 0.70398 0.7658
0.8845418 1.06148 1.0897 1.3783
C Yield(%) Ir-192
SP3 0 0.000126 0.00183 0.000043 0.00472 0.033
0.00023 0.00262 0.2867 0.3 0.8281
0.000185 0.00721 0.00664 0.000737 0.4783
0.03184 0.000022 0.00443 0.04515 0.000426
0.000039 0.0823 0.05309 0.000053 0.0000149
0.002923 0.000528 0.0000108 0.0000124
C Define Materials
C Ir-192
M1 077192 1
C Air
C M2 6000 -0.00012 7000 -0.75527 8000 -0.23178 18000 -0.01283 GAS=1
C Stainless Steel
M3 025000 -0.02 014000 -0.01 024000 -0.17 028000 -0.12 026000 -0.68
C M3 8000 -0.888 1000 -.112
M4 025000 -0.02 014000 -0.01 024000 -0.17 028000 -0.12 026000 -0.68
C Water
M5 1000.04p 0.6667 8000.04p 0.3333
PRINT 50
NPS 10000000
Is there any information other than this, such as a line number where the error occurred?
C Cell Cards
C Surface Cards
4 SO 40 $ Graveyard
C 11 SO 10
19 SO 30
20 SO 0.9
21 SO 1.1
C 22 SO 325
C Data Cards
C tally card
*F4:p 23
0.0010 4065
0.0015 1372
0.0020 615.2
0.0030 191.7
0.0040 81.91
0.0050 41.88
0.0060 24.05
0.0080 9.915
0.0100 4.944
0.0150 1.374
0.0200 0.5503
0.0300 0.1557
0.0400 0.06947
0.0500 0.04223
0.0600 0.03190
0.0800 0.02597
0.1000 0.02546
0.1500 0.02764
0.2000 0.02967
0.3000 0.03192
0.4000 0.03279
0.5000 0.03299
0.6000 0.03284
0.8000 0.03206
1.0000 0.03103
1.2500 0.02965
1.5000 0.02833
SI1 0.029
SI2 0.348
C Yield(%) Ir-192
C Define Materials
C Ir-192
M1 077192 1
C Air
C Stainless Steel
C Water
PRINT 50
NPS 10000000
The software is called MCNP
Yes the other line is
"bad trouble in subroutine pass0 of imcn"
Which was already clear. My question is, is that stuff in the file CODE in "MCNP" ?
Yes that is the format of MCNP's code.
Putting this inside [ code]...[ /code] tags (without the space after the left bracket) improves readability:
Code:
C Cell Cards
C Surface Cards
4 SO 40                           $ Graveyard
C 11 SO 10
19 SO 30
20 SO 0.9
21 SO 1.1
C 22 SO 325
C Data Cards
C tally card
*F4:p 23
     0.0010             4065
     0.0015             1372
     0.0020             615.2
     0.0030             191.7
     0.0040              81.91
     0.0050              41.88
     0.0060              24.05
     0.0080               9.915
     0.0100               4.944
     0.0150               1.374
     0.0200               0.5503
     0.0300               0.1557
     0.0400               0.06947
     0.0500               0.04223
     0.0600               0.03190
     0.0800               0.02597
     0.1000               0.02546
     0.1500               0.02764
     0.2000               0.02967
     0.3000               0.03192
     0.4000               0.03279
     0.5000               0.03299
     0.6000               0.03284
     0.8000               0.03206
     1.0000               0.03103
     1.2500               0.02965
     1.5000               0.02833
SI1 0.029
SI2   0.348
C Yield(%) Ir-192
C Define Materials
C Ir-192
M1 077192 1
C Air
C Stainless Steel
C Water
PRINT 50
NPS 10000000
The error message that says "bad trouble in subroutine pass0 of imcn" suggests to me that there is a syntax error that is causing a proto-parsing check to fail.
I note that some of the cell definitions have been commented out, which suggests to me that this is in-flux code, wherefore presumably some version of it didn't get the error. Similarly, a presumably previous definition for M3 is commented out, and currently M3 and M4 have the same values in their definitions. Another indication is that the (line 68) comment 'C Energy Spectrum of Ir-192 (MeV)' isn't followed by a corresponding specification in the non-ignored code. That may not be a problem, but it strongly hints at the existence of an earlier version.
If you've modified a file that consisted of code that was error-free prior to your modifications, you might want to look at at your changes first, or start with the latest working predecessor, and reintroduce your changes 'one by one' (to the extent to which doing that would be syntactically acceptable).
A cursory glance at some of the MCNP documentation indicates to me that a dump may be available in an output file.
The description in the MCNP User's Guide leads me to be a bit suspicious regarding the use of the # (complement operator) on line 38, but I haven't seen enough samples or a complete enough description to justify my suspicion as other than unfounded.
I don't know MCNP, so a syntax error in a sample of it isn't very likely to be obvious to me, so if I could not locate the errant line by reference to a message or dump, I would try naively and systematically to isolate the line: I would progressively comment out lines by prepending, e.g., C test1, to a block of lines, and when the error stopped being triggered, uncomment part of the block, until I had, in a manner akin to a binary search, homed in on the faulty line.
The issue with the file is geometry. The cells must fill every portion of space exactly once. This is not the case with this file. There are overlaps between cells so that some parts are defined more than once.
It looks like the problem child is cell 17. It overlaps with cells 23 and 24. One possible thing you could do is to exclude cell 17 from them by adding #17 to their definitions. The comment says cell 17 is "drive cable" so it probably needs to extend to the boundary of the model. But I can't be sure that is what you want.
The easiest way to see this sort of error is usually to use the plotting package. The first thing you see (after changing all the tabs to blanks, MCNP 6.2, right?) if you plot this in the default mode is that cell 17 has dotted red line outline over most of its length.
As of MCNP 6.2 it looks like VisEd is no longer part of the package. You should be sure to set up the plotting utility, if you have not already done so. That might require you to get an x-windows emulator for MSWindows if you are using it. On LINUX I can't tell you how to set it up because in this place that is done by our system manager.
Folks, if you don't know MCNP it isn't helpful to complain about "what code?" and similar remarks. The OP's question is reasonable. It is perfectly reasonable to refer to an MCNP input as "a code." The # operator that sysprog complained about introduces vertical format, a properly formed method of inputting data in MCNP. Nearly all of this is unhelpful distraction from the actual problem.
Regarding that, my post included:
The section of the manual on the complement operator includes:
MCNP User's Guide said:
#n means that the description of the current cell is the complement of the description of cell n. #(...) means complement the portion of the cell description in the parentheses (usually just a list of surfaces describing another cell).
I don't agree with your assessment that I "complained about" the # operator; I think that I merely suggested that its use might be among the things in the code that should be evaluated for the possibility of syntactic incorrectness.
Everyone who responded was clearly focused on being of assistance to @khary23 in getting the error corrected. I concede that given that, as I said:
sysprog said:
I don't know MCNP
I was to some extent shooting in the dark; however, the procedure that I suggested I think reliably would find the part of the code that caused the error condition to be raised, and that would facilitate correction of the code.
In this instance, knowing MCNP, as apparently you do, presumably should allow for a more helpful response, but I don't think that should be taken to mean that the well-intentioned, and not incogent, efforts of others, should be castigated as unhelpful complaining.
For my part, other than emplacing the code within the appropriate BB tags, had your post already been present, I'd have not presented any potentially distracting material.
Regarding X-Windows on Windows, CygWin/X is available at https://x.cygwin.com/
Hi,
you have a cookie-cutter because of cell 17.
try this modification :
C Cell Cards
C Cell Cards
17 4 -4.01 -10 IMP:p,e=1 $ drive cable -4.81
23 5 -0.99355 20 -21 10 IMP:p,e=1 $ Tally Cell
24 5 -0.99355 21 -4 10 IMP:p,e=1
C Surface Cards
10 RCC 0 0 -0.246 0 0 -39.753 0.043 $ drive cable
And no error
