Uniform Continuity: Definition & Applications
Uniform continuity is defined for a function f with domain D, stating that for any ε > 0, there exists a δ > 0 such that for all s, t in D, if |s - t| < δ, then |f(s) - f(t)| < ε. This definition emphasizes that the condition must hold for all pairs of points within the specified distance, not just for selected points. The utility of uniform continuous functions is highlighted in the context of the Darboux integral, where Cantor's theorem asserts that any continuous function on a closed interval is uniformly continuous, facilitating the proof of the integral's definition.
  • Understanding of basic calculus concepts, particularly continuity.
  • Familiarity with the definitions of limits and epsilon-delta proofs.
  • Knowledge of the Darboux integral and its properties.
  • Awareness of Cantor's theorem and its implications in analysis.
  • Study the formal definition of uniform continuity in detail.
  • Explore the implications of Cantor's theorem in real analysis.
  • Learn about the Darboux integral and its relationship with uniform continuity.
  • Investigate graphical representations of uniform continuity for better conceptual understanding.
Mathematicians, students of real analysis, and educators seeking to deepen their understanding of uniform continuity and its applications in calculus and integration theory.
saminny
Hi,
This may sound lame but I am not able to get the definition of uniform continuous functions past my head.
by definition:
A function f with domain D is called uniformly continuous on the domain D if for any eta > 0 there exists a delta > 0 such that: if s, t D and | s - t | < delta then | f(s) - f(t) | < eta. Click here for a graphical explanation.
I can just choose "delta" that is a large number that will make any 2 points on the curve satisfy this condition. 1/x would be uniform continuous if I simply choose a large enough delta.
moreover, what is the utility and application of uniform continuous fynctions?
thanks,
Sam
I think what you're missing is that in the definition, the part that says
"if s, t D and | s - t | < delta then | f(s) - f(t) | < eta"
actually means
"if for all s,t in D such that |s-t|<delta, we have | f(s) - f(t) | < eta."
So it does not suffice that you can find two points of D a distance less than delta apart that satisfy | f(s) - f(t) | < eta, but rather, the definition is saying that all the points in D that are a distance less than delta apart must satisfy | f(s) - f(t) | < eta !
saminny said:
Hi,
For starters, in order to prove that the Darboux integral is defined for any continuous function on a closed interval, Cantors theorem - which states that a continuous function on a closed interval is uniformly continuous - is used and then the uniform continuity is used to prove that the integral is defined.
  • · Replies 18 ·
  • · Replies 40 ·
  • · Replies 22 ·
