Uniform convergence of function sequence
The discussion centers on the uniform convergence of the function sequence defined by f_k(x) for k = 1, 2, ... on the interval [0, 1]. The pointwise limit of the sequence is established as f(x) = 0, but it is concluded that f_k does not converge uniformly to f due to the discontinuity of the limit function across the defined intervals. Furthermore, the integral of f_k over [0, 1] does not converge to the integral of the limit function, reinforcing the non-uniform convergence of the sequence.
  • Understanding of pointwise and uniform convergence of sequences of functions
  • Familiarity with the definition of integrals and properties of limits
  • Knowledge of piecewise functions and their behavior
  • Basic calculus, specifically integration techniques
  • Study the definitions and differences between pointwise and uniform convergence in detail
  • Learn about the implications of the Dominated Convergence Theorem on integrals
  • Evaluate the integral of piecewise functions to understand convergence behavior
  • Explore examples of sequences of functions that converge uniformly and those that do not
Mathematics students, particularly those studying real analysis or advanced calculus, as well as educators seeking to clarify concepts of convergence in function sequences.
complexnumber
For [tex]k = 1,2,\ldots[/tex] define [tex]f_k : [0,1] \to \mathbb{R}[/tex] by
[tex] \begin{align*}<br /> f_k(x) = \left\{<br /> \begin{array}{ll}<br /> 4k^2x & 0 \leq \displaystyle x \leq \frac{1}{2k} \\<br /> 4k(1 - kx) & \displaystyle \frac{1}{2k} < x \leq \frac{1}{k} \\<br /> 0 & \displaystyle \frac{1}{k} < x \leq 1<br /> \end{array}<br /> \right.<br /> \end{align*}[/tex]
1. Show that [tex]\{ f_k \}[/tex] has a pointwise limit, [tex]f[/tex], but that
[tex]f_k \nrightarrow f[/tex] uniformly.
2.Does [tex]\displaystyle \int^1_0 f_k(x) dx \to \int^1_0 f(x) dx[/tex]?
1. Does [tex]\{ f_k \}[/tex] converges pointwise to [tex]f = 0[/tex] because for every [tex]x[/tex] there
is always a [tex]k[/tex] such that [tex]\displaystyle \frac{1}{k} < x[/tex]? But taking limit of each interval results in the following function
[tex] \begin{align*}<br /> \lim_{k \to \infty} f_k(x) = \left\{<br /> \begin{array}{ll}<br /> 0 & 0 \\<br /> \infty & \displaystyle 0 < x \leq \frac{1}{2k} \\<br /> \infty & \displaystyle \frac{1}{2k} < x < \frac{1}{k} \\<br /> 0 & \displaystyle \frac{1}{k} \\<br /> 0 & \displaystyle \frac{1}{k} < x \leq 1<br /> \end{array}<br /> \right.<br /> \end{align*}[/tex]
Which one is the correct limit function? What is the reason for the sequence to be not uniformly convergent? Is it because the limit function [tex]f[/tex] broken into intervals is not continuous? But what if the limit function is [tex]f(x) = 0[/tex]?
2. Is this because limit and integrals cannot be exchanged due to sequence not uniformly convergent? What else do I need to prove?
I find it easier to think about these questions by picking arbitrary [itex]x_0[/itex] in the interval and seeing what happens. If you pick zero,[itex]f_k (0) = 0[/itex] and this is trivial. If [itex]x_0[/itex] is non-zero, indeed you can find large enough k such that [itex]\frac{1}{k} < x_0[/itex], and for that k and larger,[itex]f_k (x_0) = 0[/itex]. This is for arbitrary [itex]x_0[/itex], so you can see how the limit function is just f = 0.
The main problem for you seems to be determining the uniform convergence. I would work straight from the definition:[itex]\forall \epsilon > 0,[/itex] there exists a K such that k > K implies [itex]|f(x) - f_k(x)| < \epsilon[/itex] [itex]\forall x \in \left[ 0,1 \right][/itex]. In your case, [itex]f(x) = 0[/itex] for all x.
I think it's easiest to work from a contradiction. Suppose you had such an epsilon, and such a K. What would happen near zero?
As for the second part, I think it would be very informative to actually evaluate the integral
[tex] \displaystyle \int^1_0 f_k(x) dx[/tex]
  • · Replies 40 ·
